adjustable suspension
Postby LEV_101 » Fri Feb 17, 2006 12:05 am
hey, can someone help me on adjustable suspension. what might i be looking for on some 2nd hand adjustables ? what should i look out for....?
its for my 20v non super strut levin :P
thnaks
LEV_101
Postby RunningRich » Fri Feb 17, 2006 7:54 am
Crap, I totally forgot to email you back sorry. I managed to pick one up in auckland. Sorry but time was of the essesence as my GF's car got wriitten off three weeks ago and we are still waiting for the insurance payout! Hopefully that is all I need for the ST205 for a while!
Cheers, hope I didn't put you to any trouble. Must come say hello some time I'm in Taupo.
Richard
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Leon » Fri Feb 17, 2006 7:54 am
Don't forget, you'll have to factor into your budget $300 - $400 for LVVTA certification, assuming it is a roadgoing car! That trips over heaps of people
Re: adjustable suspension
Postby bad20v » Fri Feb 17, 2006 10:25 am
WTF??? Wat are you guys on about? Back to the topic at hand..... :?
LEV_101 wrote:hey, can someone help me on adjustable suspension. what might i be looking for on some 2nd hand adjustables ? what should i look out for....?
thnaks
You wont find adjustables for non-s/strut trueno levins listed practically anywhere. :(
But, if you ask for AE92 corolla adjustables, you will find that there is a wide selection available. :D
The non-s/strut ae101's have the same basic subframe and suspension setup as the AE92 corolla's. So if you are looking for suspension bushes, balljoints and other bits ask for AE92 corolla parts. But, the part that I found was different between the two was the Lower Front Control Arm Inner Rear Bush (bit of a mouthful). These do not match for some reason.
If you are looking for a really nice set of adjustable coilovers, give Shock Absorber Services a ring. They do a set for your car for about $1200 and they look similar to the D2 anodised sets. Or you can price up a D2 set.
Hope this helps you a bit. When I had my AE101 Trueno non-s/strut, I was working for SAS and did quite a bit of research into what parts fit to it from other models and what doesn't. :D
Thank-You.
bad20v
Postby Malcolm » Fri Feb 17, 2006 11:03 am
RunningRich wrote:Crap, I totally forgot to email you back sorry. I managed to pick one up in auckland. Sorry but time was of the essesence as my GF's car got wriitten off three weeks ago and we are still waiting for the insurance payout! Hopefully that is all I need for the ST205 for a while!
Richard
ever feel like you accidentally replied in the wrong thread? :lol:
Postby wde_bdy » Fri Feb 17, 2006 12:26 pm
As someone pointed out recently, TRD coilovers designed for your model will not require certing if all other requirements are met for ground clearance, travel etc.
Callum
wde_bdy
Postby ~SlideWays~ » Fri Feb 17, 2006 1:38 pm
purple_beasty wrote:As someone pointed out recently, TRD coilovers designed for your model will not require certing if all other requirements are met for ground clearance, travel etc.
Callum
What what what?
Ive got TRD coilovers on my ae92 and the wof is due soon, does that mean I wont need a cert for the suspension!? Or will the wof guy just see coilovers and say wheres the cert?
~SlideWays~
Postby Mr Revhead » Fri Feb 17, 2006 1:41 pm
yeah i did a big double take too.
but its correct. TRD is considered OE under the definition laid out by the LTSA. you may need to point out the definition to them.
last post here:
http://forums.toyspeed.org.nz/viewtopic.php?t=39824&highlight=adjustable
as purple beasty kindly pointed out to me 8)
Postby Ako » Fri Feb 17, 2006 2:11 pm
What about the 100mm part of the rule though? Yes they are height adjustable, but if you can get it under 100mm surely it should be cause for looking at?
I have no idea, just curious thats all. Whats going rate for a set of brand new TRD coilovers for say a Supra?
Ako
Postby wde_bdy » Fri Feb 17, 2006 3:05 pm
The fact you can adjust it below 100mm is irrelevant, it only matters if you do adjust it under the 100mm threshold.
Callum
wde_bdy
Postby Leon » Fri Feb 17, 2006 4:45 pm
Interesting ... I wonder if the same applies for Ralliart for Mitsi, Nismo for Nissan and suchlike?
Postby Mr Revhead » Fri Feb 17, 2006 5:05 pm
yes, as long as they are actually part of the parent company
Postby ~SlideWays~ » Fri Feb 17, 2006 5:52 pm
Bugger I think that just went out the window for me. I've got Cusco camber plates, would that mean cert for me?
~SlideWays~
Postby BigDon » Fri Feb 17, 2006 6:37 pm
Yup, if you don't have TRD (i.e. OE) top plates then you will need a Cert as I understand it. Though nothing a can of blue paint and taking the Cusco sticker off and stamping it with TRD won't fix. (If you don’t want to cough for a cert for a while/ever).
Though I have never seen a set of TRD adjustable top plates in all the searching for a set I have done, but I am sure someone wiser than me could point you to some.
K Sport is another cheap Taiwanese coilover you can get, seem pretty much the same as the D2 from what I have seen of them and around $1200 plus fitting but that is piss easy, just don’t forget to get a wheel alignment straight after!
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby 4-AGE 4-LIFE » Fri Feb 17, 2006 7:27 pm
give SAS(suspension auto services) a call they will help u out
im working at the christchurch branch and adj coilovers are available but i think the have to brought in from malaysia
they are called BC coilovers
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby Mr Revhead » Fri Feb 17, 2006 8:58 pm
TRD dont to camber plates
Postby Fortyone.co.nz » Fri Feb 17, 2006 10:14 pm
BigDon wrote:K Sport is another cheap Taiwanese coilover you can get, seem pretty much the same as the D2 from what I have seen of them and around $1200 plus fitting but that is piss easy, just don’t forget to get a wheel alignment straight after!
Small correction, K-Sport is Japanese designed, Taiwanese made =D (I'm just being picky, incase someone starts a confusion-argument stating they thought they were Japanese..) And they are pricey for AE92/others =/
Are AE100 items suitable?
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby Fortyone.co.nz » Fri Feb 17, 2006 10:15 pm
Mr Revhead wrote:yeah i did a big double take too.
last post here:
Also very interesting to know. Thanks!
Fortyone.co.nz
Postby vvega » Sat Feb 18, 2006 1:22 am
i have some bistien hight ajustablies off a ae 101 non ss
there a upside down desing so have the massive 55mm stantions
i could be perswaded to sell them
v
vvega
