I want to get a gearbox from auckland down to here in wgtn. Who will be able to do this? It doesn't look like a normal courier co. will do it unfortunetly
Approx cost would be good aswell if anyone has done it before
Any help would be appreciated!
sergei wrote:arround 60-80 dollars, try Freighlines, 19 Druces Rd Manukau Auckland 0-9-262 0104
All_Fours wrote:I sent an e51 from aucks to chch for $56 with dailyfreight.
downside is you have to pack it on a pallet and drop off/pick up from depots
~SlideWays~ wrote:Daily Freight is part of Mainfreight by the looks of it. I found their web site but it doesn't seem to be working. I wanted to see where their depots are so I could tell the seller.
~SlideWays~ wrote:All_Fours wrote:I sent an e51 from aucks to chch for $56 with dailyfreight.
That sounds good. I just need to find the easiest option for the seller. I guess you would need to supply the pallet wouldn't you? .
2LTR Rona wrote:~SlideWays~ wrote:Daily Freight is part of Mainfreight by the looks of it. I found their web site but it doesn't seem to be working. I wanted to see where their depots are so I could tell the seller.
Quite correct, they are one in the same, Mainfreight is the parent company from memory (been a while since I managed their mobile accounts)![]()
use http://www.mainfreight.co.nz/ for the contact info, lists both companies for ya
Daily Freight Auckland
42 O'Rorke Rd, Penrose, Auckland
PO Box 12-441, Penrose,Auckland
Phone: 09 579 2089 Fax: 09 579 4382
Mainfreight Auckland
12 Southdown Lane, Penrose
PO Box 14 038, Panmure
Phone: 09 526 0950 Fax: 09 526 0959
Hope that helps
Users browsing this forum: No registered users and 27 guests
