MR2 Factory tint
MR2 Factory tint
Postby Alex B » Mon May 01, 2006 11:19 pm
Ive been told that the "AS2" engraved in my glass means it has a factory tint. Can anyone tell me what sort of level ti is so i can legaly tint my car?
Cheers Alex.
Postby flat_0ut » Sat May 06, 2006 8:30 pm
is'nt it already tinted?
flat_0ut
Postby Alex B » Sun May 07, 2006 12:11 am
Ummmm yes. Hence it being "AS2" glass, but i want to go darker. IE to 35%
Postby flat_0ut » Sun May 07, 2006 9:31 am
Most glass found on modern vehicles are already tinted at the maximum and have the code AS1 (windscreens) & AS2 to indicate this? dunno if that helps
flat_0ut
Postby Andy » Sun May 07, 2006 11:17 am
Why not bring it to a tinting place and get the glass measured?
Andy
Postby Alex B » Sun May 07, 2006 7:52 pm
flat_0ut wrote:Most glass found on modern vehicles are already tinted at the maximum and have the code AS1 (windscreens) & AS2 to indicate this? dunno if that helps
Um its no where near 35%, its more like 90%. And andy, bit rude using their gear if your not going to use them to tint your car.
Postby cr1mnl » Sun May 07, 2006 7:58 pm
testing station measured mine when i got pink stickered. mabye try your local vtnz or on road
www.ology.co.nz
cr1mnl
Postby Alex B » Sun May 07, 2006 8:01 pm
Chur, sounds like a plan. I just assumed as2 is a standard level of tint.
Postby Andy » Sun May 07, 2006 11:11 pm
Get a quote while you are there, it might be so good that you can't refuse. Plus you are giving them a chance to get a potential customer.
Andy
