AE86 diff gear into AE85 housing?
Postby l1ttle_d3vil » Mon Jun 26, 2006 8:33 pm
Just wondering if I was to get all the internal gear out of an ae86 diff (LSD diff head, axles etc), and modified the ae85 diff housing so the '86 head will fit, would everything fit in?
or are axles different widths, lengths etc?
im guessing if it is just the axle width which is different, there would be particular seals which could be fitted to take up the difference in space.
and the diff head size, i know the AE86 diff heads are bigger than '85s, but in what way? how are diff heads measured? width ways or from the back of it to the front of the flange?
this may be entirely impossible, but wondering if it could be done with a bit of work.
Postby fangsport » Mon Jun 26, 2006 8:41 pm
why would you not use the AE86 housing as well???
the mounting hole for the diff head would be too small on the 85 diff.
fangsport
Postby Truenotch » Mon Jun 26, 2006 8:55 pm
And the axles are different measurments arent they?
Truenotch
Postby wde_bdy » Mon Jun 26, 2006 11:12 pm
Axles between T and S series are supposedly the same. Don't know if in zenki or kouki but assume whichever is the earlier one (zenki I think). However centres are not, S is 8 bolt and T is 10 bolt and any attempts to interchange would be costly and probably pointless.
http://www.toymods.net/forums/showthread.php?t=7385
Callum
wde_bdy
Postby l1ttle_d3vil » Mon Jun 26, 2006 11:20 pm
wde_bdy wrote:any attempts to interchange would be costly
that is not an issue.
wde_bdy wrote:and probably pointless.
why is this? because changing the studs alone still wont let it fit? (as in the inner part of the diff head/housing would need to be made larger to allow the bigger 86 diff head too)
sorry if this is answered in the link you gave, haven't read through it all yet. will go through it tomorrow.
Postby wde_bdy » Mon Jun 26, 2006 11:24 pm
Costly and pointless because unlikely to fit no matter what you do and you can get a suitable T series housing for pretty cheap.
Callum
wde_bdy
Postby AE85coupe » Tue Jun 27, 2006 1:53 pm
yep like he said, difficult and pointless, just pull a t series housing out of a corona, has bigger brakes than an ae85 anyway and has the same head as an ae86
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Drifter4ag » Tue Jun 27, 2006 5:20 pm
No ... why not try fit a hilux head in to that housing ?
Anyway .. its a waste of time ... i wouldnt even convert to T series unless it was with facelift axles ... but even then i would still be 50/50 on it
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Jebus » Tue Jun 27, 2006 5:27 pm
Cos money aint a thang'
Jebus
Postby l1ttle_d3vil » Tue Jun 27, 2006 10:12 pm
l1ttle_d3vil wrote:Cos money aint a thang'
depending on what is getting done, some things dont cost me money...all I have to pay for is parts, and seeing as I already have an ae85 diff housing all setup for a ke35 I was just curious if it might be easier to buy just an 86 head + axles and fit that to my current diff housing with a bit of grinding and welding.
seeing as that is not the case, I might just stick to my sh!tty ae85 diff head which spins one wheel everywhere for now... :lol:
Postby Drifter4ag » Tue Jun 27, 2006 10:46 pm
get the hilux setup from trademe at the moment .. $550
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby l1ttle_d3vil » Tue Jun 27, 2006 11:06 pm
Drifter4ag wrote:get the hilux setup from trademe at the moment .. $550
already have that sitting in my garage, and its non-lsd and overkill for my little 88kw of bluetop grunt :wink:
what would be the minimum kw you'd want to warrant putting something like that in? could pick up an LSD for one of them for around $400, so have an LSD diff setup for a ke35 for well under $1000 (all up).
probably looking at about the same or more for an ae86 lsd rear end, atleast the hilux diff will never blowup...
Postby wde_bdy » Tue Jun 27, 2006 11:39 pm
l1ttle_d3vil wrote:what would be the minimum kw you'd want to warrant putting something like that in? could pick up an LSD for one of them for around $400, so have an LSD diff setup for a ke35 for well under $1000 (all up).
Ignore what horsepower would justify it and think $$$ value for the results. The only downside is the weight, and unless you are talking serious race car you won't ever notice.
Callum
wde_bdy
Postby l1ttle_d3vil » Wed Jun 28, 2006 8:42 pm
what sort of weight difference is there between an ae85/6 diff and a hilux one then? the car is noticably slower with just 1 extra person in it so Im wondering how much different the hilux diff would actually make.
there are a few hilux LSD's around for less than $300, so this could actually be worth it. especially seeing as I am looking at turboing my car in the future...
Postby suberimakuri » Wed Jun 28, 2006 11:32 pm
heh.
i ran hilux diff with stock 4age, and now with modified na 4age.
You're talking about 10kg or so in weight and more drivetrain inertia.
S and T axles are different.
i would do it again with a bluetop or 5k just so i don't have to muck about with tiny stupid T series gear.
why don't you guys just do stuff.
suberimakuri
Postby fangsport » Thu Jun 29, 2006 12:45 am
Karl_Skewes wrote:heh.
because it would be far too easy to follow a tried and tested method :wink:
for sure, i don't put much HP to the ground. but it still amazes me that a standard T-50 and T-series rear can take the punishment, although the 4.1:1 ratios do get noisy very quickly :lol:
fangsport
Postby Jebus » Thu Jun 29, 2006 5:32 pm
Im with Karl, I chucked a Hilux LSD behind a stock 4AGE and love it, I regret not doing it when I was running a 5K.
Cos theres a strong belief within toyspeed that a car can be built from hopes and dreams and a new thread about doing stuff to it each week.
Jebus
Postby Snoozin » Thu Jun 29, 2006 5:37 pm
Post of the day.......... that is gold my friend. :lol:
Snoozin
Postby l1ttle_d3vil » Thu Jun 29, 2006 7:51 pm
Jebus wrote:Cos theres a strong belief within toyspeed that a car can be built from hopes and dreams and a new thread about doing stuff to it each week.
hah I wish it would be that easy. I was always under the impression that a hilux diff would be way to heavy for a standard 4age, obviously not the case though.
are all hilux axles the same then? as in it doesn't matter what diff head I get, it will fit the axles on the diff I have at the moment? thats what I've heard at some point before, so just wanting to make sure before I go buying an lsd diff head that doesn't fit!
Postby Dell'Orto » Thu Jun 29, 2006 8:04 pm
Can get ARB airlockers for Hilux diffs too :D probably not alot of use for a road car, but cool none the less :lol:
