Hi,
As many will know, i just bought a 1997 Curren.
I want to put an alarm on it.....but unsure of what to go for??
Ive not got much of a budget, really wanting the cheapest, decent alarm around.
Anyone got any ideas?
Ta
Callum
This engine immobiliser is made to and has passed the latest 2001 Australian and New Zealand Standards AS/NZS 4601:1999 Vehicle Immobilisers. Once installed and armed, any attempt to hot wire your car will be unsuccessful. The indicators will flash and the horn or siren (optional) will sound for 30 seconds. System will then reset. System will alarm up to three times if attempts continue from any one tamper source.
Features include:
- Micro- processor controlled technology
- 2 button 2 channel Code Hopping 433MHz remote control - more than 100 million individual codes prevents code- grabbing by would- be thieves
- Electronic twin relay circuits for two different points of immobilisation installation
- Panic button personal safety feature
- Emergency 5- number pin override makes car immediately drivable in case remote transmitters are lost or damaged
- Auto- arming - when engine is stopped, 30 seconds later the immobiliser will automatically arm
- Horn or siren output (siren not included - see below)
- Distinct arm and dis- arm audible chirp confirmation when remotes are used advises system status (if horn connected or optional siren fitted)
- Easily up- graded to a full function alarm (see LA- 8975 below)
- Ignition sensing - tampering with ignition will automatically sound horn (if connected) or siren (optional)
- Heavy duty 2x 40 amp immobiliser relay circuits
- Up to 3 remote controls can be programmed into each system
- 20mA ultra- low current draw when armed has little effect on battery drain life
- Up to 20 metre remote operation range under most circumstances
- 3x sector isolation (both immobilisation circuits and input sensors)
- 2nd channel output trigger for boot release (may require solenoid purchased separately)
- Armed ground output to control accessories
- Armed status memory - system will return to same state of arming if power is removed and then restored, thwarting theft by cutting battery power to the car
- External sensor input function enables connection of optional shock sensor
IMMOBILISER - WHAT YOU GET:
- Black box electronic module with all of the above features, made to Australian and New Zealand Standards
- 2x 433MHz remote control key fobs
- High security all- black wiring harness (numbered for installation purposes), including central locking output wiring
- Flashing dashboard LED
- Installation and user manuals
- Requires car to be fitted with Central Locking for doors to automatically lock
- purchase Cat LR- 8830 for 4 door and Cat LR- 8838 for 2 door to add central locking to your car.
