Bazda Vs. matt dunn??
Postby Paulio » Fri Jul 21, 2006 1:09 am
kinda interests me. (assuming the psi and hp down the strip)vBazda has the blacktop running about 25psi down the track with 440hp atw and gets a 12.9 and matt dunn has the silvertop running about 18psi with 280hp and gets a 12.39.
does that just prove that you're better off lightening your car than cranking the poundage up or what?
paul
Paulio
Postby Boosted_162 » Fri Jul 21, 2006 1:49 am
Not really a fair comparison, considering both the cars are totally different, and so are the tracks/dynos that they got their figures on.. Would be better to compare them side by side if at all really...
Postby Brick » Fri Jul 21, 2006 3:26 am
fwd vs rwd, i bet bazda was still wheelspinning across the finish :lol:
Brick
I know Kung Fu
Postby deaf_rattle » Fri Jul 21, 2006 7:30 am
wasnt barrys 12.9 done on his last set up? with much less power?
Postby EVLGTZ » Fri Jul 21, 2006 8:09 am
Yep Barry hasnt even run his car yet with the new setup
Would be expecting a fair bit lower than a 12.9 once he has it all sorted.
The 12.9 was done with the old setup and somewhere around 200kw at wheels
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby EVLGTZ » Fri Jul 21, 2006 8:11 am
Not_paul_from_whangarei - have you got that new car of yours on the strip yet?
Previous owner talked it up a storm - would be good to see what it is capable of
EVLGTZ
EVLGTZ
Re: Bazda Vs. matt dunn??
Postby Bazda » Fri Jul 21, 2006 9:37 am
not_paul_from_waiheke wrote:kinda interests me. (assuming the psi and hp down the strip)vBazda has the blacktop running about 25psi down the track with 440hp atw and gets a 12.9 and matt dunn has the silvertop running about 18psi with 280hp and gets a 12.39.
paul
if u read my profile right it says 4agte in the 12.9
new car is 7agte.
I will be expecting low 11s or even high 10s with some slicks.
I have similar kws to that integra in christchurch thats a road car and he ran a 10.94 so i'll be trying to match that :D
Postby samlloyd » Fri Jul 21, 2006 8:40 pm
That integra is awesome. Fast asleep.
samlloyd
Postby Paulio » Sat Jul 22, 2006 9:17 am
ok that explains the 12.9 then. fair enough.
Paulio
Postby Paulio » Sat Jul 22, 2006 9:24 am
EVLGTZ wrote:Not_paul_from_whangarei - have you got that new car of yours on the strip yet?
hey dude
no not yet, too busy putting a bit of money into it, pulling it down later on today to check the rings, bearings. fixing the suspension up a bit etc and other misc things, we don't have any dodge w.o.f stations down here so it wouldn't pass with the cutties and no cert.
once it's legal though i'll try get it on a dyno then a track and see what kind of power it has.
paul
Paulio
Postby IH8TEC » Sat Jul 22, 2006 12:04 pm
cutties and no cert, i dont know many dodgy wof guys that will give you a wof for that. :?
Postby deaf_rattle » Sat Jul 22, 2006 1:36 pm
IH8TEC wrote:cutties and no cert, i dont know many dodgy wof guys that will give you a wof for that. :?
even if there was, why would you drive with a car with cut springs?
muppets
Postby Bazda » Sat Jul 22, 2006 7:05 pm
not_paul_from_waiheke wrote:ok that explains the 12.9 then. fair enough.
hey
The guy you bought this off said it was rebuilt etc only done XXX kms, why r u already pulling it apart???
Postby matt dunn » Sun Jul 23, 2006 1:10 am
hey
It doesnt matter what the rings and bearings are like,
as If you pull it apart you should not re-use old one anyway.
Plus once you have undone the rod bolts and head studs you throw them and the gasket away.
Makes it an expensive look even if there is nothing wrong.
Matt
Postby BBBrad » Sun Jul 23, 2006 3:50 pm
Sorry for bringing up an old subject. Just that there was mentioning earlier about the 10 sec honda down south, then I remembered the locked thread on "turbo 4age vs turbo vtec". I then had a look over at the honda site....anyone read what theyve been saying? Seems like they think that 330wkw @ 27psi is a joke.
Why do honda motors seem to make a whole heap more power at the same boost???
My new car...99 mr-s
BBBrad
Postby flygt4 » Sun Jul 23, 2006 3:55 pm
seems simple to me , they run stupidly higher compression. an engine with 11:1 c/r will only need small amounts of boost to crank out some serious power ,but with a higher risk of something going wrong.
most of the 4age turbo conversions run as low as 8:1 , sacrificing response but also hopefully being more reliable.
ive seen in a magazine somewhere a ferrari that had been turbocharged with similar results, it only needed like 7psi to double the factory output :D
flygt4
Postby Al » Sun Jul 23, 2006 3:56 pm
BBBrad wrote:Why do honda motors seem to make a whole heap more power at the same boost???
The head design and cams.
Al
Postby flygt4 » Sun Jul 23, 2006 3:56 pm
and that too
flygt4
Postby Mr Revhead » Sun Jul 23, 2006 4:45 pm
i can quite honestly say that every turbo honda iv seen with my own eyes has been no where near as good as an equiv toyota :?
and blow up a hell of a lot more often
Postby 4000GT » Sun Jul 23, 2006 4:50 pm
Last time I checked Matt car is setup for circuit?
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
