donuts and flexis :)
Postby IH8TEC » Mon Jul 24, 2006 10:28 pm
can anyone here or someone know where to get cheap 2 1/2 inch mild steel mandrel donuts? and 2 1/2 inch flexi?
Postby Al » Mon Jul 24, 2006 10:39 pm
Autoflex flexis can be had at Tyco flow control, around $50.
Al
Postby IH8TEC » Tue Jul 25, 2006 10:10 am
just called them and they are $95, anyone know any cheaper?
Postby 99gtt » Tue Jul 25, 2006 4:11 pm
What are you using them for as mandrel bends would be better than doughnuts.
SOON TO BE 500 HP
99gtt
Postby IH8TEC » Tue Jul 25, 2006 4:12 pm
dumppipe off turbo, wih flexi going under sump
Postby drftnmaz » Tue Jul 25, 2006 4:54 pm
tube and steel in east tamiki.... about $25 for a 180degree mandrel m/s bend. and they have bins of s/s seconds for cheap as well... will normally hook up deals as well.
if you find any cheap flexi's i'd be keen as too hear i'm just about to make a new exchast (stupid new law) :x
drftnmaz
Postby sergei » Tue Jul 25, 2006 5:41 pm
99gtt wrote:What are you using them for as mandrel bends would be better than doughnuts.
what are the advantages of mandrel bend vs doughnut?
Postby 99gtt » Tue Jul 25, 2006 6:24 pm
doughnuts are manufactured as that and require welding on the seam for strength. The bends are mandrel bent so dont loose any wall strength. Thats my best explination unless any one else can describe in more detail.
SOON TO BE 500 HP
99gtt
Postby Caveman » Tue Jul 25, 2006 6:36 pm
99gtt wrote:doughnuts are manufactured as that and require welding on the seam for strength. The bends are mandrel bent so dont loose any wall strength. Thats my best explination unless any one else can describe in more detail.
Huh?
stainless tube is seam welded as well so its the same difference. If your getting into cold drawn steel expect to pay an arm and both testicles.
Steel and tube are pretty good, I have a shit load of schedual 40 2.5' elbows you can have for $5 each, Mild steel. S/S is better though because decreased weight. Tube benders in east tamaki on cryers road sell 2.5 elbows for $15 as scrap or $25 new. Scrap is ok to use, the only difference is its not completely round (near enough for exhaust)
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Bazda » Wed Jul 26, 2006 11:23 am
how the hell can u justify that lol
and for strength...its for an exhaust, hence the flexi.
im the one making the downpipe, its a pretty tight fit so a mandrel bend would not fit into the space we have or thats what we would be using as donuts are expensive.
