What I did today...
What I did today...
Postby matt dunn » Sat Sep 02, 2006 11:14 pm
Well, at 3.30 today may car looked like this,
So a few hours later,
it now looks like this,
Took a bit more than i thought.
Had to swap over all the accessories, replaced rear main seal, removed sump and fitted the baffeled one with turbo return etc etc.
Not too bad for a few hour works including going to have tea at the In-laws.
Matt
Tomorrow, hopefully, will get all the rest back together.
Matt
Postby AJz » Sun Sep 03, 2006 12:12 am
damn good effort man :D
I had vtax :(
AJz
Postby Bling » Sun Sep 03, 2006 12:44 am
I hope you lifted that in by hand..... its how real men do it anyway...
ok, so just poor people without engine hoists :oops:
Postby crispy'86 » Sun Sep 03, 2006 9:22 am
Good effort Matt, just a feshen up for the new season for the engine was it?
crispy'86
Postby flygt4 » Sun Sep 03, 2006 9:59 am
not a bad effort. whats the specs on the engine? same again ?
flygt4
Postby matt dunn » Sun Sep 03, 2006 12:43 pm
No, the old engine is still fine, just sitting in the corner waiting,
This one is a new setup, in the never ending search for more power.
Can't raise the boost as the class I race in has an 18psi limit,
so raised the compression ratio instead.
Will see how it goes next weekend hopefully.
Matt
Postby crnkin » Sun Sep 03, 2006 4:58 pm
yes! high compression for the win!
deaf_homo "currrently yes"
crnkin
Postby matt dunn » Sun Sep 03, 2006 7:38 pm
Gone up from 7.8 to 9,
but the modified head and aftermarket cams are still on the other engine,
so will be interesting to see if there more power, less power, or the same?
Time ( and a dyno plot) will tell.
Matt
Postby trueno_20v » Mon Sep 04, 2006 1:21 pm
Thinking of getting a bigger turbo?
ADMIN EDIT: signature too large
trueno_20v
Postby Adamal » Mon Sep 04, 2006 1:38 pm
matt dunn wrote:Can't raise the boost as the class I race in has an 18psi limit
Now why would he want a bigger turbo when he can't go over 18psi? ;)
Postby trueno_20v » Mon Sep 04, 2006 1:55 pm
bigger turbo on same boost would make more power..?
trueno_20v
Postby flygt4 » Mon Sep 04, 2006 6:37 pm
would also sacrifice response , depends how responsive he wants it. tho with raised compression it should be able to spool a slightly larger turbo just as fast as before.
flygt4
Postby matt dunn » Mon Sep 04, 2006 8:27 pm
I may go for a bigger turbo when i go for an engine with more cc's.
Matt
Users browsing this forum: Bing [Bot] and 6 guests
