Surge tank
Surge tank
Postby Emperor » Mon Sep 04, 2006 6:18 pm
Where can I get surge tanks from?
What size is reccomended and what fuel pump? (Walbro 550hp? external?)
For NA 13B
Emperor
Postby Jebus » Mon Sep 04, 2006 6:28 pm
Mines 2L, got it made by Michael Sinclair, its a really really nice tank, awesome build quality. Cost $120 + fittings. I use an Airtex fuel pump, its a bolt in upgrade for a VL turbo, so can support alot of power, but is fine on my N/A 4AGE as well, been a real good pump so far, nice and quiet too.
When you plumb it up, get 3 inlets/outlets. One on top being an overflow back to the fuel tank, the one at the top on the side being the feed from your low pressure lifter pump, and your EFI Return line. and the bottom one is the outlet to your engine via the high pressure pump.
Be sure your fuel return line goes back into your surge tank, otherwise you can run your high pressure pump dry.
Jebus
Postby YeMs » Mon Sep 04, 2006 7:40 pm
injected NA 13b?
Your local Hybrid Elite tech
YeMs
Postby Jebus » Mon Sep 04, 2006 8:00 pm
Batty with aftermarket ECU running in Pro 7 is my guess.
Jebus
Postby atmosports » Mon Sep 04, 2006 9:05 pm
HiTech motorsport in pukekohe,auckland usually ahve a good rang in stock or esle they can custom make to suit your requirements, they do heaps of rotary stuff as well so could be worth a look/call.
atmosports
Postby Stealer Of Souls » Mon Sep 04, 2006 10:47 pm
Jebus wrote:Mines 2L, got it made by Michael Sinclair, its a really really nice tank, awesome build quality. Cost $120 + fittings. I use an Airtex fuel pump, its a bolt in upgrade for a VL turbo, so can support alot of power, but is fine on my N/A 4AGE as well, been a real good pump so far, nice and quiet too.
So really he wants four connections. Two in the top, one for return line, one for feed pump. One in the side at the top as the overflow back to fuel tank, and one at the bottom as the delivery pump outlet. Also, if you can get a conical bottom that'd be better too.
If you're really trick inclined you could get a simple level switch installed near the top. This would warn you when you're down to your last 2L of gas.
The taller and skinner the better, and stilling fins are always interesting but a bit overkill.
'86 AE85.5 Levin
Stealer Of Souls
Postby 85AW20v » Tue Sep 05, 2006 3:00 pm
Would there be any problem running your std in-tank pump as your lifter pump? And then your high pressure external to the injectors? Or would the std in-tank not keep up?
See ya
Simon
85 MR2 20v
85AW20v
Postby Bazda » Tue Sep 05, 2006 3:22 pm
for surge tank setup you usually run low pressure intank pumps that dont flow that good. as it will fill up the surge tank too fast making the fuel circulate back into the main tank thus making the fuel hotter.
Postby RedMist » Tue Sep 05, 2006 3:39 pm
Stealer Of Souls wrote:If you're really trick inclined you could get a simple level switch installed near the top. This would warn you when you're down to your last 2L of gas.
I have a low fuel warning similarly constructed. My facet draw pump is mounted close to the external ali panels. When it runs dry it vibrates so badly it drums on the panel. Instant and bloody loud warning! Last 2l or 6km to go.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Jebus » Tue Sep 05, 2006 3:45 pm
Hehe yeh I have mine doing the same, around hard corners, you can hear the low pressure pump running dry for a couple of seconds as it vibrates away on thin support panel, then chugs away like normal when it sucks some more up. Yay for main tank with no baffles, makes me really appreciate how much difference the surge tank makes.
Jebus
Postby RedMist » Tue Sep 05, 2006 7:19 pm
I run a surge tank as I discovered the fuel went into suspension in the foam of the cell whenever I went over a large jump. The EFI pump sucked up a little bit of air and took "forever" (in racing terms) to clear. Made you want to get out and kick the heck out of her.
Those low pressure pumps are amazing when dry. I can't believe how much they vibrate. Mine is mounted on cotton reels to stop vibration destroying the pump... but when its dry it bloody near vibrates the car!
RedMist
Postby Emperor » Tue Sep 05, 2006 7:21 pm
Yeah, 13B Injected, running Link ECU
Emperor
