Wheel alignments
Wheel alignments
Postby levinguy » Fri Sep 22, 2006 2:53 pm
my car was pulling to left heaps so i got a wheel alignment today
after i had it done still pulls to the left just not as much
have i had a crap job done? or can it be something else apart from the wheel alignment
car is a ae101 gtz
levinguy
Postby RS13 » Fri Sep 22, 2006 3:14 pm
Jammed brake callipers, tyre pressures, imbalanced drive, some FWD cars favour the side with the shorter driveshaft, even a mild camber on the road itself will cause most cars to pull left slightly, even if you can't see it.. I wouldn't worry about it, unless its' uncontrollably bad!
RS13
ALIGNMENT
Postby TOYROTA » Fri Sep 22, 2006 4:19 pm
sounds to me you have low caster on the left hand front which basicly means your alignment guy only adjusted your TOE and didnt bother with your castor or camber. where bouts are you??
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby dougsop » Fri Sep 22, 2006 5:15 pm
i've heard sometimes is caused by the suspensions
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
dougsop
Postby Ae92typeX » Fri Sep 22, 2006 5:37 pm
get a results sheet which has a summary of the before and after?- lots of places doing that now.
as above, all sorts of possibilities. If its ever had a knock, its possible the car is a wee bit out of line and they adjusted as much as possible.
but yeah, if its only a little dont worry. if it botheres you go back to where you had it done and confront them about it.
Ae92typeX
Postby MrOizo » Fri Sep 22, 2006 5:39 pm
Ae92typeX wrote: if it botheres you go back to where you had it done and confront them about it.
sooner rather than later
I wrote a email to beaurepairs head office in aussie about the place i went to not bothering about camber and they did it again free of charge :) did the camber that time.
bling bling
MrOizo
Toyspeed Legend
Re: Wheel alignments
Postby TrouserFxGt » Sat Sep 23, 2006 9:07 pm
levinguy wrote:have i had a crap job done? or can it be something else apart from the wheel alignment
Quite a lot of the time it is the tyres that cause the car to 'pull'. Do a rotation and report back.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
