Someone want to do some fabrication work for me?
Postby strap-on » Sun Oct 15, 2006 2:43 pm
basically I need a pair adaptors made up to fit a filter to the mouth of my carbourators, I have a little spacer off the top that can be used as a template for the flange and then it will just need a tube on the top that once I work out how long it needs to be will double as a trumpet,
so yeah anyone wanna do the work? I know theres people on here like action dan who can do awesome work just not quite sure if this is his cup of tea.
strap-on
Postby 86_rolla » Sun Oct 15, 2006 5:01 pm
are these going to be turmpets for your dual carb? i am/was looking at getting trumpets and putting sock filters on but theres sfa room there haha, ill be keen as a bean aswel
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby strap-on » Sun Oct 15, 2006 5:02 pm
yeah this is cos i cant fit a K&N on as is, there ends up being about 30 mm room i think
strap-on
Postby 86_rolla » Sun Oct 15, 2006 5:18 pm
so r u going to just run a trumpet set up and put sock filters over the trumpets? thats what im planning to do hoepfuly
Ex cars: 2E corolla
86_rolla
Postby strap-on » Sun Oct 15, 2006 5:36 pm
Im not sure now lol i just rememberd how small the gap is it may be i will have to get something tricky done once ig et the right length worked out.
strap-on
Postby 86_rolla » Sun Oct 15, 2006 5:48 pm
yeh i guess you could take the air filter box off, bolt some trumpets on and then raise the bonnet a bit to get a bit of air goin to them haha, it is a very very tight space. Theres some 75mm ones on tardme but i dunno if there is even that much room haha
Ex cars: 2E corolla
86_rolla
Postby Dell'Orto » Sun Oct 15, 2006 5:51 pm
Do you not have access to a lathe on base? Surely it wouldnt be too hard to spin up a set of tubes, then get someone to weld them onto a flange.
Postby strap-on » Sun Oct 15, 2006 5:54 pm
Hmm that is true then i can get what i want and maybe make some for rolla 86 as well
strap-on
Postby AE85coupe » Sun Oct 15, 2006 6:26 pm
hey just thought i would warn ya that the length of the trumpet and the trumpet design makes a huge difference, you could just weld on a piece of pipe.. or your could do it properly and reap the rewards
:wink:
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby strap-on » Sun Oct 15, 2006 8:00 pm
yeah hance why im trying to figure out how long they need to be i really just need an adaptor, but im reading an article that redmist posted ages ago that explains it all quite nicely so pnce ive finished readin i should be able to wrok out what i wanna do
strap-on
Postby 86_rolla » Tue Oct 17, 2006 8:59 am
any news, im keen on some
Ex cars: 2E corolla
86_rolla
Postby RS13 » Tue Oct 17, 2006 7:10 pm
Hah! a carb Honda thread, lol! How does the carb setup work with the EF? Is the carb downdraft? I have a DA with dual carb, I want a decent filter (not for performance obviously, maybe a bit more "roar"!) but my carbs are sidies.. ie the filter is pointing at the firewall, and I have about 60mm to work with!
RS13
Postby 86_rolla » Tue Oct 17, 2006 7:33 pm
yeh the EF's are the same (sidedraft), theres not much room but it can be done,
just need to chuck some sock filters on and she will b a minta lol
Ex cars: 2E corolla
86_rolla
