how ae85/86 suspension should be
Postby msv madness » Tue Oct 31, 2006 11:12 pm
as above realy the pics speak for themselves, no bullshit taiwanese shit here,
koni shocks even length arms and watts linkage
www.msv-racing.com, for any fabrication and general mechanical work, aeroquip hose fittings power steer hoses, oil / water turbo hoses, samco hosing, roll cages, custom suspension, engine transplants, driveline transplants, stainless manifolds, alloy, cro moly, stainless fabrication.
msv madness
Postby eritate » Tue Oct 31, 2006 11:35 pm
haha $&#$% yer
thats $&#$% cool :D
Good work
Btw what Diff is that ? hilux ?
I am a timewaster. Ignore anything I say
eritate
Postby msv madness » Tue Oct 31, 2006 11:37 pm
yip it sure is hilux diff and 17 x 9.5s on the rear
msv madness
Postby Akane » Wed Nov 01, 2006 5:39 am
What's wrong with the "taiwanese shit"?
Postby msv madness » Wed Nov 01, 2006 10:32 am
you said it yourself its shit
msv madness
Postby Akane » Wed Nov 01, 2006 10:42 am
BC's are made in taiwan, and they're quite decent.
Postby johntramp » Wed Nov 01, 2006 11:05 am
BC are nothing compared to the likes of apexi
johntramp
Postby Dunny » Wed Nov 01, 2006 11:16 am
Any reason why you have mounted the watts link to the diff housing? I would have thought that would screw with your cornering geometry
Dunny
Postby Mr Revhead » Wed Nov 01, 2006 11:27 am
a who?
koni, bilstein, proflex, drummond.. now THEY are suspension companies to drool over 8)
Postby toyae86 » Wed Nov 01, 2006 11:39 am
thats why the shocks are koni adjustables
but we wont mention the keepers hehe
it will be interesting to see how the new x5k king springs go
toyae86
Postby Snoozin » Wed Nov 01, 2006 11:43 am
Mr Revhead wrote:a who?
If ever catch you drooling on my suspension...... :?
Snoozin
Postby Mr Revhead » Wed Nov 01, 2006 11:45 am
its ok, i ge tot work with proflex :P
Postby msv madness » Wed Nov 01, 2006 12:36 pm
Dunny wrote:Any reason why you have mounted the watts link to the diff housing? I would have thought that would screw with your cornering geometry
theres not much point in mounting it to the chassis is there?
if its not mounted to the diff its not going to hold the diff in lateraly which is its only function
msv madness
Postby msv madness » Wed Nov 01, 2006 12:37 pm
yeah they are decent suspension companys and you wont get 36 way adjustable this that and everything for 1200 will you haha
wats wrong with drooling on suspension?
msv madness
Postby Dunny » Wed Nov 01, 2006 1:32 pm
I was probably asking more along the lines of why not have the link arms mounted to the diff nearer the shock mounts and the watts link pivot independent of the diff housing...each to their own I guess. Everyone has a theory and when it comes to suspension set up or geometry there are plenty of opinions.
Adjustment of settings or ability to adjust is your friend
Dunny
Postby Punter » Wed Nov 01, 2006 2:12 pm
My old mans rally car was setup like that, with the pivot on the diff. After shearing it off we decided to change it.
Build a tower down with different spaced holes and mount the arms to the diff. Like a V8 supercar.
Punter
Postby msv madness » Wed Nov 01, 2006 4:13 pm
regardless of which way it is setup it still has to have one central pivot point otherwise there is no movement of the arms at all
msv madness
Postby Punter » Wed Nov 01, 2006 5:31 pm
Yea the main reason we changed it is to make it adjustable.
Punter
Postby NZ_AE86 » Thu Nov 02, 2006 7:07 pm
All very pretty but is it tested? Have you got a decent LSD in that Diff?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Ah
Postby GH » Thu Nov 02, 2006 9:22 pm
Dont bars in watt link need to be level to work?
GH
