This is what could happen to the motors you don't want:
Having finally found a 2JZ-GE with an A340E Trans, with complete ECU and Loom... the mods on my truck have finally started...
Gallery
Truck did have a 1KZ:
This supra did have a 2JZ:
Both are now out, so Rick at 4wd accessories is going to put the 2JZ above into here:
First step is to change the Input shaft, oil pump and bellhousings over, Aceomatic should be doing that this week and giving my auto a service.
So the plan is/was:
* Lots of research - Done, Have wiring diagrams, Toyota Service Manuals etc... only one missing is A343F Trans manual
* Find 2JZ-GE complete with Trans, ECU and loom - Done
* Remove 1KZ - Done
* Swap Trans bits over
* Install 2JZ with original A343 Trans, Serviced and ready to go
* Install New Springs and Shocks for 100mm Lift
* Borrow Riks tyres for Cert
* Buy own 35's
* Get Muddy![/list]
