sergei wrote:I will tell you one thing: we fitted GT starlet ECU (EP82 man) to manual cynos (EL44?), it was straight swap no loom change needed. I opened up both ECU and they had almost identical pin outs. We used GT injectors and map sensor. We left Cynos inlet manifold. Although I think ACIS did not work...
