Anyone interested in AE92 & AE100 brake upgrade kits?
Postby strx7 » Wed Feb 07, 2007 9:31 pm
I'm in the process of putting big brakes on my AE104 which uses the same front hub carriers as AE92 & AE100 etc. I'm using 280mm discs and S4/5 RX7 4 pot Calipers, these fit inside MOST 15 x 6.5 and 15 x 7 Mags and larger.
An adapter needs to be used to mount the caliper to which then inturn bolts to the hub carrier, I will be getting these parts profile cut. Would there be any interest out there in these Brackets? I can supply the part number or even supply new DBA 280mm discs with the correct dish height for this all to work, and with enough time I could probably even source some calipers and supply them with new brake hoses is you wanted to go that far.
If you'd be intested Let me know in this thread or PM me.
Shane
Postby Barks » Wed Feb 07, 2007 9:53 pm
I'd be interested in having a look if you don't mind.... The brakes on the GTZ aren't too bad, but you can never have too much stopping out on the track...
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
Postby strx7 » Wed Feb 07, 2007 10:16 pm
are you a member of Tauranga Mount Motorsport Club?
Postby Bazda » Wed Feb 07, 2007 11:33 pm
im keen for brackets, i was looking into this a little while ago but didnt hav the time to sort out brackets. What kinda costs are we looking at for brackets?
Postby Barks » Thu Feb 08, 2007 6:56 am
Yeah, I am :)
I work in Te Puke too....
Barks
Postby strx7 » Thu Feb 08, 2007 10:15 am
oh true, I've been on committee for the past few years.
Do you do club events?
Postby neo » Thu Feb 08, 2007 10:19 am
Rmember cats, this will stuff up the bias, and you will need to modify the brake lines..
Just putting the twin pots (+mintex + larger rotors) onto the front of my 101 has screwed up the bias.
My next plan is to remove the factory prop. valve and to insert the willwood one on the rear line(s). hopefully this works better than it did on the mini :oops:
neo
Postby strx7 » Thu Feb 08, 2007 10:19 am
i'll be working out the braket shape in the next couple of days. Then getting it profile cut. Then I'll be able to let you's know a price. I'm using Nissan 180SX 2.0 Front discs which are 280mm diamater with a 49mm height, removal of the backing plate off the hub is required. I can supply these discs for $130 ++ brand new for a pair. They need to be drilled to 4 x 100 and I can arrange that on top.
Postby strx7 » Thu Feb 08, 2007 10:20 am
for sure, i'm converting to rear discs & calipers too which i will also possibly be able to offer as a kit, along with a suitable booster and master cylinder etc if required. I'll be running an adjustable bias valve, as you would expect on a competition car.
Postby Barks » Thu Feb 08, 2007 10:38 am
I was doing a few club events a little while ago, but I've gone to doing solely circuit stuff, and as you know circuit events are few and far between, so I tag onto other club's events. Haven't had my Trueno out since last year when I had a small *incident* with the armco at Pukekohe. Started to just repair it, but decided halfway through to find a few more horsepower in her, and it kinda snowballed from there. ATM the car's sitting in the workshop in Te Puke waiting for me to hoist the new engine in and start connecting things up.
Barks
Postby strx7 » Thu Feb 08, 2007 11:19 am
i'm planning on doing some of the winter series dual sprints etc at taupo this year once the corolla is going.
Postby thaphatty » Thu Feb 08, 2007 11:31 am
Actually, My cars also going as well, and id be interested in joining the Tauranga Mount Motorsport Club.
Is there any chance of a sign-up form? or a url? or someone i could call?
thanks in advance
thaphatty
Postby strx7 » Thu Feb 08, 2007 12:03 pm
yip its all on www.tmmc.org.nz
Postby Cakky » Thu Feb 08, 2007 5:41 pm
whats the price for a full package looking to be around?
1989 Corolla GT sedan blacktop 20v
Cakky
Postby matt dunn » Thu Feb 08, 2007 9:53 pm
neo wrote:..
Remember that AE101 are FWD so are likely to have a split diagonal braking system where the rear are not on a separate circuit to thye front like a RWD car.
Split diagonal on FWD has the left rear and right fron on one circuit
and the right rear and left front on the other.
Fitting an aftermrket adjustable bias means re-plumbing the whole system sometimes.
