Started the inevitable killing of rust in my MA45, mainly in the rear hatch. Failing warrant due to one of the hinges being toast.
Only problem is, i know there is rust behind this piece of steel
Only problem being, its a close cavity, so i can't get my dye grinder in there. So does anyone know of any good spray on rust killing stuff that i can just put a hose on, stick it in there and then go nuts? Would also have to put a prevention layer over the top afterwards, all the kilelrs i use leave bare metal. which in this case, would cause lots of problems
After this... the otherside of the hatch/its hinges then the engine and box transplant...then trimmings... THEN PAINT woo!
pending on gettign the other one up here though... damn.
