the project section is still subject to normal forum rules...
http://forums.toyspeed.org.nz/viewtopic.php?t=34777
- Images posted into threads directly via [img] tags should not be bigger than 800x600 pixels in most instances. If you need to refer to a bigger image, just post a URL instead of using img tags.
We have been very very slack on this, but this will be changing.
We understand pics are very important to the project section, and we in no way want less.
But we have to limit the size...
So if a large pic is needed, please link it.
If resizing is a PITA (it is to a n00b like me), try PixResizer:
http://www.google.co.nz/search?q=pixresizer
If you have existing over size images, please resize them (with the free tool linked above), or set them up as links, not embedded images.
