postfach wrote:this should probably be in general, but meh.
what fuel are you using? i made 196 with the standard intercooler, and 234 with a front mount
avinesh wrote:thats good power man i used 98 octane fuel it was on dyno dynamics which i here reads low but all i wanted to know was my afr 10.1 is ok aye
Mmm, Boost wrote:avinesh wrote:thats good power man i used 98 octane fuel it was on dyno dynamics which i here reads low but all i wanted to know was my afr 10.1 is ok aye
10:1 is bloody rich, theres a bit mpore power to be found there if you can lean it out a bit.
the fallen303 wrote:what else had you done to the car when you got the 234? got 238 out of mine with the stock i/c but higher boost and modified turbo setup
avinesh wrote:where did you get your coil packs from incase mine goes bye bye
Dragger_Dan wrote:Is it just me or do all dynos in New Zealand seem to read low? In fact I wouldn't be suprised if the majority of dynos in the world are claimed to have read low.
Users browsing this forum: No registered users and 22 guests
