I bolted up my clutch and one of the bolts i had was about 5-10mm longer than the others.
Would this throw it off balance? I mean the things spinning at over 100 revs a second when the engines near redline.
But then its only a few grams and the whole flywheel + clutch would weigh at least 10kg so there could be enough centrifugal force to keep it stable.
I don't have much knowledge of applied physics, just the concepts
Would it wear out the engines main bearing noticeably faster?
Just would mean id have to pull the bloody box out again.
