a ke20 question
a ke20 question
Postby Matty104 » Tue Sep 18, 2007 10:20 pm
ive got a ke20, and the questions im keen to get answered are
considering that its dereg, i was wanting to put a 4k into it, but having a quick glance over there was a tag in the engine bay that said 3k, (guessing thats whats ment to be in it) so back to the question, if i was to put a 4k into it would i have to do anything special when it goes to get re reged? of will they just register it saying it has that engine?
and what about a 4age into it, just a thought is it quite hard to do , i mean having to get speedos and all that done?
also althought its been covered i cant get a strait answer, when getting re reged (or re vinnd or what ever its calld ) does it just go through a complience check over and if all is well it will be road legal again?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby HachirokuGTV » Tue Sep 18, 2007 11:00 pm
I think if you put in a 4K or even a 5K no-one would know the difference.
4age would be way more work and cost unless you can find a complete conversion for your 20.
HachirokuGTV
Postby Mr.Phreak » Tue Sep 18, 2007 11:21 pm
Depends if whoever is doing the work bothers to check engine numbers or not.....
If the car is running atm, I'd get it on the road as it is, then do the engine swap...
Mr.Phreak
Postby Matty104 » Wed Sep 19, 2007 7:52 am
yea i didnt really think they would notic as there isnt much difference between the motors is there, its a rolling body at the moment, engine won't be coming into the picture till next year but thought id find out wot needs to be done before i go and restore it and find out it was a waste of time
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Matty104 » Wed Sep 19, 2007 7:55 am
could it be defined by the fact that it wont be 25% more powereful than the standard motor therfore it won't need a cert, or is it more than 25% powerful?
'Tron E30 Massif
89 BMW 325sci
Matty104
Re: a ke20 question
Postby rollaholic » Wed Sep 19, 2007 8:05 am
Matty104 wrote:also althought its been covered i cant get a strait answer, when getting re reged (or re vinnd or what ever its calld ) does it just go through a complience check over and if all is well it will be road legal again?
once its been through a compliance check they will issue you a warrant and an MR2A, which will enable you to register the car. i believe theres also an additional charge for the new number plates.
i cant say for sure on re-vinning but when it comes to imports the engine number is checked and recorded, so chances are you will be pulled up on it if the car doesnt have the 3k its supposed to have.
Postby Mr.Phreak » Wed Sep 19, 2007 9:22 am
Matty104 wrote:could it be defined by the fact that it wont be 25% more powereful than the standard motor therfore it won't need a cert, or is it more than 25% powerful?
Technically it's 20% but that's not really for engine swaps, that's more of a guideline for engine mods
The one that'd require you to get a cert if it was noticed would be the capacity rules
Mr.Phreak
Postby thegreatestben » Wed Sep 19, 2007 10:10 am
I would say you'd be pretty safe with changing to a 4k. if any one picked you up on it, it would be good as we'd know not to go to that guy for a re vin :lol:
thegreatestben
Postby Matty104 » Wed Sep 19, 2007 10:50 pm
so what do they actually do , ?, check it , then stamp a new number into the fire wall or what?, is there any other legal way i can get around it, like by buying the reg plates etc from another 20 or is that not possible?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Dell'Orto » Wed Sep 19, 2007 10:57 pm
Using plates from another vehicle is very very illegal. Just put heaps of grease/dirt over the engine number if you're worried about it.
All they'll do is give it a good going over then stick a VIN plate on the firewall.
Postby Matty104 » Wed Sep 19, 2007 11:01 pm
yea i assumed it was , but no harm in checking, yea it wont be for a while yet anyway as the panelling is only just underway, but just wanted to make sure geting re reged ws possible before starting, can a 4k bolt strait into 3k mounts?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Dell'Orto » Wed Sep 19, 2007 11:05 pm
Yep.
Postby Infinite » Wed Sep 19, 2007 11:06 pm
u can swap tags its only rivets.... plenty of people do it just dont tell people u have done it and esp not the testing guy
Lots
Infinite
Postby Matty104 » Wed Sep 19, 2007 11:19 pm
i think il just take my chances with the 4k , and if it got caught out id look 4 a 3k just to get the complience if it came to that , i assume youve got something like 28 days to fix stuff like a normal warrent?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby 79rolla » Wed Sep 19, 2007 11:39 pm
yeah 4k should be sweet. have one in my ke30 and vin plate says 3k and havint been pulled up for it yet (its been in for about 5ish years now i think)
past: AE82 FXGT
79rolla
Postby Matty104 » Wed Sep 19, 2007 11:48 pm
yea its just that compliance check, but owell should work out fine though, cheers for all the info guys
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Infinite » Thu Sep 20, 2007 12:20 am
last time i had a compliance done they were to lazy to find the engine number and told me todo it.... and turnd out the engine had been changed so they dont notice just say the last 3k blew and its another 3k >_<
Lots
Infinite
Postby rollas22 » Sat Sep 22, 2007 5:32 pm
Grind the numbers of where it says "4K.............." on the engine block an no1 will know the difference... The engines all look the same... but seriously y would u wana stick with the old slow motor when there are so so so many options you can do... (funds do take alot of the decision making in the long run tho)
Post some pics up of your KE20 (mate of mine is striping a KE20 so he may have some parts of interest)
KE-Corolla's for life!!!
rollas22
Postby Matty104 » Sat Sep 22, 2007 7:22 pm
i was going to post a thing in the project section the other day but couldnt figure out how to post pics up.how do i do that , ?, don't have many pics yet, it needs a shit load of work yet haha,
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Bling » Sat Sep 22, 2007 10:36 pm
