Air compressor
Air compressor
Postby trdtrueno » Mon Oct 29, 2007 9:30 pm
hi everyone. was just looking on trademe at air compressors as i was thinking of buying one so i could paint my car.. was just wondering if this one would be alrite for the job??
http://www.trademe.co.nz/Trade-Me-Motor ... 842364.htm
Also wat about the ones you can get from repco or supacheap?? are they anygood for painting your car??\
any help apreciated
trdtrueno
Postby Ae92typeX » Mon Oct 29, 2007 9:39 pm
imo that would be fine. Ive painted with a smaller one than that.
repco/supercheap ones are ok/fine, the small ones lag behind so you can only do a pannel at a time well. Make sure you get a water trap if whatever you choose does not have one & go for a smaller diameter hose as apposed to the fat arse ones sold for less.
Ae92typeX
Postby Sideros » Mon Oct 29, 2007 9:48 pm
I work for repco, Get something like a CM13 which off the top of my head is about $700 retail. They should be able to give you a good cash discount and it should be ok for painting a car... However you couldn't go past the WS16 which is 15cfm 70l tank and 3hp... About $1800 though :(
Sideros
Signwriter
Re: Air compressor
Postby fangsport » Mon Oct 29, 2007 11:34 pm
trdtrueno wrote:hi everyone. was just looking on trademe at air compressors as i was thinking of buying one so i could paint my car.. was just wondering if this one would be alrite for the job??
any help apreciated
find out what the quoted 'free air' is. displacement only indicates pump size.E.G. i spent $1500 on a Ingersoll-Rand BD15 (15CFM), but has only 12cfm 'free air', and anyless and you may as well take mouthfulls of paint and sneeze it onto the car :wink:
fangsport
Postby GTCRSHR » Tue Oct 30, 2007 12:21 pm
you could hire a good one if its not something you are going to use all the time
Nothing to see here ...
GTCRSHR
Postby gleem » Tue Oct 30, 2007 9:58 pm
are these ones any good? im looking at getting one too
http://www.trademe.co.nz/Building-renov ... 805524.htm
gleem
Postby fangsport » Tue Oct 30, 2007 10:02 pm
gleem wrote:are these ones any good? im looking at getting one too
same as the one above, but with a different sticker on it
fangsport
Postby gleem » Tue Oct 30, 2007 10:12 pm
haha yeh, also what does the water trap do?
gleem
Postby fangsport » Tue Oct 30, 2007 10:18 pm
traps water.
reduces the amount of water that enters the flexible pressure line.
if painting ir using air tools, id recommend getting a decent one fitted as the OEM ones on cheap compressors are usually quite crappy.
fangsport
Postby Dr J » Tue Oct 30, 2007 10:54 pm
my flat mate brought a 40l 2.5 hp one from super cheap and a decent airline and we painted a car with that it worked fine as long as you stop ever now and then to let the compressor recharge.
also just a note that you prob don't want to use a air line thats been used for air tools such as rattle guns etc because it may have oil in it which will lead to oil in your paint. not good
hope that helps
Vehicles:
1983 Nissan Fairlady 280zx 2+2
"CAPS LOCK IS CRUISE CONTROL FOR COOL!"
Dr J
Postby fangsport » Tue Oct 30, 2007 11:06 pm
Dr J wrote:my flat mate brought a 40l 2.5 hp one from super cheap and a decent airline and we painted a car with that it worked fine as long as you stop ever now and then to let the compressor recharge.
hope that helps
40l and 2.5hp counts for nothing with air, it the amount of free air that counts. the heat generated from constant operation, the more water is created, that is the very reason you need a big pump.
fangsport
Postby Dr J » Thu Nov 08, 2007 10:29 pm
im aware that its the free air that counts i was describing the compressor and explaining that it worked fine to paint a car because "trdtrueno" asked if the super cheap ones would do the job.
tank size does matter because if you have a small tank then the pump will be running more creating more heat and moisture also the bigger the pump the quicker it regains pressure and again less running and heat.
Vehicles:
Dr J
Users browsing this forum: No registered users and 38 guests
