royal purple oils
royal purple oils
Postby jaypines » Mon Nov 19, 2007 10:22 pm
Have anyone here tried to use some of these on their engines? Currently using Motul stuffs but results from here are a bit of a surprise! Have seen some articles for Royal Purple but most are related to TV Ad and network marketing etc etc..
jaypines
Postby frost » Mon Nov 19, 2007 10:25 pm
a lot of the 350z drivers use that stuff, try searching on the z forums for articles,
Postby Stu- » Tue Nov 20, 2007 9:15 am
Intersting article - makes some of the popular brands look pretty average
Project Thread
Stu-
Postby Mr Revhead » Tue Nov 20, 2007 12:52 pm
yes it does....
suspicously so!
Postby mr30%jr » Tue Nov 20, 2007 12:56 pm
i kinda didnt understand how the test related to a motor tho
REALLY simply yes...
mr30%jr
Postby sergei » Tue Nov 20, 2007 3:31 pm
My biggest issue with this test is that they did it at room temperature. They needed to heat it up to 120'C to see what really was going on. The results might of been completely different under those conditions.
Postby AceSniper » Tue Nov 20, 2007 4:34 pm
AceSniper
Postby fivebob » Tue Nov 20, 2007 5:39 pm
The test procedures are incorrect and only really test film strength not wear properties. Might be an ok test if you were looking to buy a grease, but essentially useless for selecting an engine oil :roll:
Postby Simon K » Tue Nov 20, 2007 7:38 pm
Thought that test looked familiar, it's been posted on a local forum before.
Simon K
TS Wannabe
Postby JRS » Tue Nov 20, 2007 8:36 pm
don't think much of the test procedure. if you took the cheapest, nastiest, highst viscosity oil you could get your hands on it will probably excell in this test.
meh.....
JRS
