halves in suspension JZA70
Postby d1 mule » Wed Jan 16, 2008 10:13 pm
heya im just wondering if there is anyone that would be keen to go halves on a set of adjustables for a J/M/G A70 supra?
reason being iv got a JZX81 and the rears out of 70 series supras fit in but ill have to make my own front adjustables, and the best idea i can come up with is go halves..... i dont really want to buy a set from japan too much hastle
d1 mule
Postby postfach » Wed Jan 16, 2008 10:16 pm
why dont the front ones fit?
postfach
Postby d1 mule » Wed Jan 16, 2008 11:55 pm
not sore to be honest i just no they dont lol, either different bolt spacing or completely different set up, ill look into it
d1 mule
Postby postfach » Thu Jan 17, 2008 12:11 am
I always thought they were iinterchangeable. i could be wrong though.
supra front is double wishbone, has the eyelet at the bottom and 3 studs equally spaced at approx 100mm center to center
postfach
Postby d1 mule » Thu Jan 17, 2008 12:19 am
yeah just found that out, JZX81 is the same set up as AE86, GX70,GZ10,KE70 etc etc just with different bottom bolt spacing, so to the best of my knowledge macpherson strut
d1 mule
Postby mikeBrotherd » Thu Jan 17, 2008 2:21 pm
What sorta kit are you looking for? So im guessing you would only use the REAR shocks from the kit?
How much?
    JZS147 Aristo, 2JZ-GE
    KE70 Corolla Wagon, 4K, 5spd Man
    JZA70 Supra, 2JZ-GTE, Man, TurboR
    GA60 Supra, 1G-E
mikeBrotherd
Postby d1 mule » Thu Jan 17, 2008 2:55 pm
yeah id be after the rear.
um either BC, K sport, D2 etc preferably BC
the car is going to be a "budget" drift car im hoping to build it for under $7k so cant really afford to splash out on Cusco, Tein, HKS etc
a rough guess would be $1000-$1500 tops for complete set
d1 mule
Postby MrDori » Thu Jan 17, 2008 9:24 pm
dodsons could be a go, did you wana go with s13 ones up front or what??
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby postfach » Thu Jan 17, 2008 10:28 pm
just fyi, i have bc's in my soarer, which is a track car, and they perform really well :wink:
postfach
Postby d1 mule » Thu Jan 17, 2008 10:38 pm
MrDori wrote:dodsons could be a go, did you wana go with s13 ones up front or what??
na "standard" setup but none of the local (BC, Ksport, D2 etc) make anything for the front so ill just convert the standard struts to coilovers.
why dodsons??
and Postfach, yeah thats what iv heard, ment to be better quality than Ksport and D2, i think BC make the Apexi and Buddy club Adjustables too just different colours etc
d1 mule
Postby mikeBrotherd » Fri Jan 18, 2008 9:58 am
Could be interested if your getting BC's. PM me if you do deside....just gotta save a little bit :-)
    GA60 Supra, 1G-E
mikeBrotherd
Postby d1 mule » Fri Jan 18, 2008 11:31 am
sweet man, ill do some looking today
d1 mule
