flat_0ut wrote:Coolant should be pretty straight forward to do yourself,
pyro_sniper2002 wrote:flat_0ut wrote:Coolant should be pretty straight forward to do yourself,
I take it you have done an SW20 coolant change before then?
If you jack up the back and take your time they arnt toooo bad, but still not as easy as something with the radiator at the same end of the car. Have to get all the air out of the system, this is the time consuming bit.
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
BZG|Bling wrote:lol I didn't even notice you were local![]()
i'm no expert - so take this with a grain of salt (i'm sure someone will correct me)
Easy:
oil change - easy enough to do yourself / with a helping hand if really noob
fuel injector clean - buy a bottle of injector clean from supercheap and put it in with ya petrol - done.
Not sure:
engine flush - heard bad stories, wouldn't flush my engine.
diff oil change - no idea, i'm thinking tho gearbox/diff = same oil so maybe get gearbox oil changed.
coolant system flush. - toyota could be the go for this and gearbox oil change.
If you really don't want to give it a go, i'd probably go to toyota as people have mentioned that the cooling system isn't a simple thing to flush, so you would want people working on it who deal in your model of car all the time.
