Seccond hand suspension
Postby bbq1988 » Mon Jun 23, 2008 11:57 am
Hey guys, whats your thoughts on seccond hand suspension? i have found a set of TEIN adjustables for my car for a sharp price, they came out of another caldina that had done around 100,000kms (i dont think the shocks have but cant be sure)
yes or no?
Baked, Not Fried.
bbq1988
Postby Santa'sBoostinSleigh » Mon Jun 23, 2008 1:55 pm
depends on price, and also the true age/condition/kms
just cause the car has done 100,000kms, doesnt mean that the shocks have, they could have been in quite a few different cars even!
Tein should be rebuildable however
also the spring rates need to be taken into consideration - too hard and the car will bounce/bumpsteer, too soft and well it will be more of a boaty whale!
but honestly is there much point in putting adjustables in a caldina?
i find mine with low tein springs to be a good height as well as good firmness. i had some lower springs in it prior to the teins, but i bottomed out on way way too many things.
plus obviously you will need a cert
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby bbq1988 » Mon Jun 23, 2008 2:10 pm
im considering it as i need to replace the shocks anyway, and for the price it doesnt matter if i need to cert
Baked, Not Fried.
bbq1988
Postby Santa'sBoostinSleigh » Mon Jun 23, 2008 2:25 pm
i replaced my shocks with standard ones when i put the tein springs in, that was about 50,000kms ago, when the car had done ~120,000 from memory.
retail per genuine shock is only $150 ($600 per set RETAIL - talk to our supplier ;) )
they will last another 100,000kms AT LEAST
to buy adjustables, cert them, then rebuild them sooner or later will be more spendy i imagine, but hey, each to their own
Santa's Mega Sale
Postby Bling » Mon Jun 23, 2008 2:25 pm
depends if you NEED adjustables?
if not, i'd just get some nice new KYBs and some lowering springs of some flavour (i'm sure theres many on here with an opinion of springs) Even custom (Cobra) springs would be a good choice.
if they need rebuilding, then you will spend the above amount of money on the rebuild + cost of initial buy of coilovers + cert cost.... hmmm
EDIT: beaten to the point :P
Postby TRD Man » Mon Jun 23, 2008 3:39 pm
There's nothing necessarily wrong with 2nd hand suspension as long as you know what you're getting.
Many very successful race & rally cars are running on suspension components either imported 2nd hand or bought used locally.
Most after market set ups will take an insert so all is not lost if one shock is soft or leaky.
I'm with the others on the adjustables. If you don't need them, why have them? And who really needs them anyway?
Consider also why they were removed from the other Caldina. Were they too hard? Some Japanese companies only make adjustables for circuit use and Tein, in particular, were renowned as being far too stiff for road use.
Far better to have the right shock with the right height paltform and the right spring for your application.
TRD Man
Postby Santa'sBoostinSleigh » Mon Jun 23, 2008 3:43 pm
TRD Man wrote:Were they too hard? Some Japanese companies only make adjustables for circuit use and Tein, in particular, were renowned as being far too stiff for road use.
I need some softer springs for my Tein adjustables in my FXGT racecar, they are shockingly hard and drive like arse on the road
Santa's Mega Sale
Postby Snoozin » Mon Jun 23, 2008 4:01 pm
I'd check them out thoroughly first... check for leaks, also remove the springs if you can and see how the damping is on them... also it depends on how cheap we're talking as to whether a rebuild on them will be a viable option. Teins are most definitely rebuildable in NZ though (Autolign are the agents from memory).
If you're satisifed that they're not leaking, bent and are damping as they should then I don't see a reason why not to go for it if you're happy sacrificing ride quality a bit. Worth it in the pursuit of slammage though I reckon!
Snoozin
Postby Jdawg » Mon Jun 23, 2008 4:54 pm
Example: S/TB Forester that is like driving around in a bouncy castle.
Bought 2nd hand Zero sports, maybe 50k kms, for 450. My opinion is just over 100 a corner = worth it.
Jdawg
Postby Dell'Orto » Mon Jun 23, 2008 6:22 pm
Santa'sBoostinSleigh wrote:I need some softer springs for my Tein adjustables in my FXGT racecar, they are shockingly hard and drive like ar*e on the road
Yeah but that'll involve you spending money :P
Postby Mr Revhead » Mon Jun 23, 2008 6:55 pm
Yep Autolign rebuild TEIN
as for them being too stiff..... depends on the type kit...
being in a caldina they are quite likely not too stiff as the wagon series are made with comfort in mind. Kits such as superwagon and superstreet are adjustable for levels starting softer than stock. That doesnt mean that some clown hasnt put 18kg springs in them tho!
Santa, a suspension system that is awesome on the track, will be crap on the road! and vice versa!
Unless they are in very good conditon and you can have some gaurantee of milage, i wouldnt pay any more than a few hundy for them as if they need rebuilding your probably looking at $200 each for that.
Postby Sick Puppy » Mon Jun 23, 2008 11:29 pm
Mr Revhead wrote:Unless they are in very good conditon and you can have some gaurantee of milage, i wouldnt pay any more than a few hundy for them as if they need rebuilding your probably looking at $200 each for that.
What about TRD corners? :D
Project thread here
Discussion thread here
Sick Puppy
Postby Mr Revhead » Mon Jun 23, 2008 11:33 pm
are you asking how much to pay for 2nd hand TRD coil overs?
or if i recommend TRD over TEIN?
Postby Bling » Mon Jun 23, 2008 11:42 pm
how much per corner to rebuild TRD :?:
Postby Santa'sBoostinSleigh » Tue Jun 24, 2008 9:41 am
Mr Revhead wrote:Santa, a suspension system that is awesome on the track, will be crap on the road! and vice versa!
yep, and they are probably a bit too stiff for the track too, especially in my little light car
Santa's Mega Sale
Postby bbq1988 » Tue Jun 24, 2008 10:22 am
TRD Shocks (Damper Adjustable) $1110, im leaning towards that.. no need for cert
Baked, Not Fried.
bbq1988
Postby cat007 » Tue Jun 24, 2008 10:50 am
We've got Tein height and damper adjustables in our '98 GTT.
Came with the car so not sure what the GTT's are like standard.
The car handles very well - altho the springs are a bit stiff. It'd be nice sometimes to soften them a little. The damper control's are great - altho - we had issues with the top hats corroding. No idea what happened. They looked like they were a sacrificial annode. These were about $700 for a pair - OUCH.
But yeah - tein's are a nice performance shock/spring setup.
Postby Sick Puppy » Thu Jun 26, 2008 12:39 am
Mr Revhead wrote:are you asking how much to pay for 2nd hand TRD coil overs?
Was wondering more about what second hand TRD Shocks and springs are worth, notably for the 20X series Curren & Celica... I have a set I'm considering selling, I figure this thread is as good a place as any to ask! lol
Project thread here
Sick Puppy
Postby bbq1988 » Fri Jun 27, 2008 10:19 am
Just scored the full set of teins for $400 :)
Baked, Not Fried.
bbq1988
