Legalities of ODO / Speedo and all that
Postby MrOizo » Tue Oct 07, 2008 9:43 pm
I have converted from mechanical speedo drive to electronic and the only speedo i have is on a RSM.
Is it a requitrment to have a working Odometer?
Also will the RSM suffice? or would i have to mount the speedo from the car that the electronic spoeedo is from?
MrOizo
Toyspeed Legend
Postby postfach » Tue Oct 07, 2008 9:57 pm
Yes you need a working odometer to get a wof, and it doesn't matter where the speedo came from, as long as it's accurate.
postfach
Postby MrOizo » Tue Oct 07, 2008 10:02 pm
postfach wrote:Yes you need a working odometer to get a wof, and it doesn't matter where the speedo came from, as long as it's accurate.
Cheers..
So a Apexi RSM will suffice?
Will try get me a odo... just have to find one :/
MrOizo
Toyspeed Legend
Postby Leon » Wed Oct 08, 2008 6:49 am
Is that actually in the virm?
Postby NZ_AE86 » Wed Oct 08, 2008 7:06 am
No you don't.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby durty starlet » Wed Oct 08, 2008 8:11 am
my one hasnt worked for a bout the past 4 years of wofs so im pretty sure its sweet not to have one
durty starlet
Postby barryogen » Wed Oct 08, 2008 8:27 am
dunno about cars, but when I last rode a motorbike, if it has the ability to go over 50km/h, it required one, I would assume the same rule would apply.
barryogen
2ZZ Guru in training
Postby UTERUS » Wed Oct 08, 2008 12:58 pm
Only diesel powered vehicles require an odometer, my bosses petrol patrol hasn't had a working odo for 5 years.
Speed only is fine.
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby Nuty|Mike » Wed Oct 08, 2008 1:43 pm
bo
got a copy of the virm page on speedos here if you want it ,
however it doesnt state anything in regards to odo anywhere but as far as I can understand if you have written proof it is impractical to have a speedo repaired you dont have to have one , it also says nothing about having a factory speedo in place rather then an aftermarket one.
come pick it up ill be here at work all day
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Nuty|Mike » Wed Oct 08, 2008 2:53 pm
after talking to wof guy odo isnt needed for wof however you need to have ur form of speedo visable to the driver .
so all in all ur sweet
Nuty|Mike
Postby MrOizo » Wed Oct 08, 2008 4:59 pm
Nuty|Mike wrote:bo
Sounds good then!
No can pink up, i in the big Palmies!! wwoooooaaa
MrOizo
Toyspeed Legend
Postby Nuty|Mike » Wed Oct 08, 2008 5:16 pm
if you want I can fax0r or email to yousss but yea all in all ur ok with rsm as long as its infront of ur face
Nuty|Mike
Postby postfach » Wed Oct 08, 2008 5:22 pm
Sorry, I didn't actually check, I was just going on what I got told when I went to get a wof and mine wasn't working :oops:
postfach
Postby Leon » Wed Oct 08, 2008 6:24 pm
Nuty|Mike wrote:but as far as I can understand if you have written proof it is impractical to have a speedo repaired you dont have to have one
I suspect this is not correct. Certainly I am unable to find anything to confirm this.
Postby Crimson Tears » Wed Oct 08, 2008 6:27 pm
If you can provide paperwork to prove that you are having the speedometer repaired, then you can get a WOF without the speedometer. It says so in the VIRM.
Crimson Tears
