Dual Cambelt
Dual Cambelt
Postby bs » Thu Mar 12, 2009 5:51 pm
Okay so at work today I had to put a new belt on the drop saw (other one burnt out and broke :lol: ), and it got me thinking... Why don't car's have two smaller sized cambelt's? Like a fail safe. So if one breaks the other is there to keep going untill the other goes "pop" to. Or is this just to clever? It will have its flaw's like the broken belt getting caught in everthing, and the owner not knowing that one has broken and then the other goes. I'm sure there would be ways around this tho.
bs
Postby rollaholic » Thu Mar 12, 2009 6:01 pm
cam chain
Postby Timmo » Thu Mar 12, 2009 6:05 pm
Yeah I would imagine
a) When the first cam belt broke it would likely take out the second given that both have around the same designed life.
b) Tensioners etc need to be replaced at the same time...and you cant really have two tensioners (i.e. if one failed then the cambelt would find it hard to turn ;) so you'd have to remove the cambelt/s to replace the tensioners anyway
c) camchains can be used where it is imperitive that the timing gear be fail safe or in situations where access is difficult
d) interference vs non-interference heads.
Lightweight baby
1991 MX5 Supercharged
Timmo
Re: Dual Cambelt
Postby sergei » Thu Mar 12, 2009 6:06 pm
bs wrote:Okay so at work today I had to put a new belt on the drop saw (other one burnt out and broke :lol: ), and it got me thinking... Why don't car's have two smaller sized cambelt's? Like a fail safe. So if one breaks the other is there to keep going untill the other goes "pop" to. Or is this just to clever? It will have its flaw's like the broken belt getting caught in everthing, and the owner not knowing that one has broken and then the other goes. I'm sure there would be ways around this tho.
most likely both will fail at same time ;)
Postby Lloyd » Thu Mar 12, 2009 6:08 pm
If you maintain your vehicle as the manufacturer recommends then there should be no need for a backup. And where does it stop, cast 2 cooling systems and run separate water pumps in case you get a radiator leak?
Re: Dual Cambelt
Postby bs » Thu Mar 12, 2009 6:10 pm
Yeah I tought that would most likely happen. Have another saw at work and from the motor to the blade there is three belts on the pullys connecting the two!
bs
Postby Lloyd » Thu Mar 12, 2009 6:27 pm
For grip reasons rather than reliability one would imagine?
Postby rolla_fxgt » Thu Mar 12, 2009 6:28 pm
Lloyd wrote:If you maintain your vehicle as the manufacturer recommends then there should be no need for a backup. And where does it stop, cast 2 cooling systems and run separate water pumps in case you get a radiator leak?
How about just having 2 complete engines, in case one fails, one in the front, one in the back, of course you could just run them both at the same time too if you really wanted :lol: I guess that would be about where you stopped, 3 engines would be a bit of overkill
rolla_fxgt
Postby bs » Thu Mar 12, 2009 6:28 pm
Lloyd wrote:For grip reasons rather than reliability one would imagine?
Yeah but they are toothed belts, not grooved.
bs
Postby RomanV » Thu Mar 12, 2009 6:48 pm
You could just cut your cambelt in half down the middle, see how it goes. :lol:
Postby bs » Thu Mar 12, 2009 6:49 pm
RomanV wrote:You could just cut your cambelt in half down the middle, see how it goes. :lol:
To bad I'm between car's so can't do it :P
bs
Postby cogent » Thu Mar 12, 2009 9:07 pm
Thats actually a really awesome trick for changing cambelt without upsetting timing :D
You cut the old one in half lengthways, then slip the front half off, slip the new belt half on, and cut the second half of the old belt off and finally slip the new belt on all the way :D
cogent
Postby rollaholic » Thu Mar 12, 2009 10:15 pm
ever actually tried it? haha
Postby Adamal » Thu Mar 12, 2009 10:29 pm
Timmo wrote:c) camchains can be used where it is imperitive that the timing gear be fail safe or in situations where access is difficult
God damn FRIGGEN TOYOTA! Maybe if they designed the 3S for the MR2 rather than designing the 3S and THEN deciding to chuck it in the MR2.... *Grumble grumble. Silvia owners have it easy...*
Postby Lloyd » Thu Mar 12, 2009 10:32 pm
Pfff, MR2 belts are no harder than anything else 3S engined
Postby cogent » Thu Mar 12, 2009 11:56 pm
rollaholic wrote:ever actually tried it? haha
Nope, but I seen it done on a 4AGZE by a dude on another forum.
See, its not quite 'friend of a friend' but its close!
cogent
Postby GTCRSHR » Fri Mar 13, 2009 8:47 am
you saw it on the internets ? :twisted:
Nothing to see here ...
GTCRSHR
Postby sleeektoy » Fri Mar 13, 2009 10:05 am
2T-G and 18R-G FTW with cam chains :D
pity about the FAIL on the tensioner/slipper wear
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby Timmo » Fri Mar 13, 2009 10:12 am
hehe I know your pain!
Lightweight baby
Timmo
Postby rollaholic » Fri Mar 13, 2009 11:32 am
plenty of transverse cars are a bit of a pain when its cambelt time. not as bad as passats and the like though :D
cogent - thats rofls, i might have to try it one of these days. seems to me though for the fiddle of cutting the old belt etc etc, it would be easier to just take it off... its not as if 4A's are difficult to set up. maybe if it were a quad cam sub i could understand it a little more!
