bs wrote:Okay so at work today I had to put a new belt on the drop saw (other one burnt out and broke ), and it got me thinking... Why don't car's have two smaller sized cambelt's? Like a fail safe. So if one breaks the other is there to keep going untill the other goes "pop" to. Or is this just to clever? It will have its flaw's like the broken belt getting caught in everthing, and the owner not knowing that one has broken and then the other goes. I'm sure there would be ways around this tho.
sergei wrote:bs wrote:Okay so at work today I had to put a new belt on the drop saw (other one burnt out and broke ), and it got me thinking... Why don't car's have two smaller sized cambelt's? Like a fail safe. So if one breaks the other is there to keep going untill the other goes "pop" to. Or is this just to clever? It will have its flaw's like the broken belt getting caught in everthing, and the owner not knowing that one has broken and then the other goes. I'm sure there would be ways around this tho.
most likely both will fail at same time
Lloyd wrote:If you maintain your vehicle as the manufacturer recommends then there should be no need for a backup. And where does it stop, cast 2 cooling systems and run separate water pumps in case you get a radiator leak?
RomanV wrote:You could just cut your cambelt in half down the middle, see how it goes.
Timmo wrote:c) camchains can be used where it is imperitive that the timing gear be fail safe or in situations where access is difficult
Adamal wrote:Timmo wrote:c) camchains can be used where it is imperitive that the timing gear be fail safe or in situations where access is difficult
God damn FRIGGEN TOYOTA! Maybe if they designed the 3S for the MR2 rather than designing the 3S and THEN deciding to chuck it in the MR2.... *Grumble grumble. Silvia owners have it easy...*
