new pb time
new pb time
Postby audi man » Sun Mar 15, 2009 9:42 pm
Well i got the chance to race today at the v8 nats, so racing against v8s but the only problem we found was i was hitting my rev limiter about 40meters before the finishing line so was slowing me down, anyway i ran 10.1 three times in a row at different speed any were from 130mph 135mph and 139mph the speed on my rev limiter should be 145mph, but my half track speed was good 119mph that around 190kmph at 6.4sec half track, so i have the task now to try to fix this rev limiter problem before the next drag meet, my rev limiter at the moment is set at 7800rpm i was thinking about moving it to 8500rpm and hope that should be enough to get me into the 9sec club, but it was good to drive there and to be the only import in my class that run pump gas do some 10.1sec passes then drive home were all the v8 in my class were running race gas and all were trailered.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby Bazda » Sun Mar 15, 2009 9:56 pm
Well done John, its about time as well!! :D
Postby Dell'Orto » Sun Mar 15, 2009 10:10 pm
Awesome stuff, roll on 9's 8)
Postby audi man » Sun Mar 15, 2009 10:20 pm
Dell'Orto wrote:Awesome stuff, roll on 9's 8)
9s should come soon, the funny thing was i over took a v8 that ran a 9.8 but as soon as i hit my rev limiter he over took me dam rev limiter lol.
audi man
Postby audi man » Sun Mar 15, 2009 10:22 pm
Bazda wrote:Well done John, its about time as well!! :D
Thank mate, next friday night should be 9s fingers X
audi man
Postby 2jayzgte » Mon Mar 16, 2009 9:21 am
Its been quite awhile since a Supra has run in the 9s good going i'm pretty sure its just around the corner..... :wink:
2jayzgte
Postby Lith » Mon Mar 16, 2009 9:31 am
Nice work man, good seeing this getting some sharp times! Is that still on pump gas?
2007 Mazdaspeed Axela
Lith
Postby audi man » Mon Mar 16, 2009 10:23 am
2jayzgte wrote:Its been quite awhile since a Supra has run in the 9s good going i'm pretty sure its just around the corner..... :wink:
As soon as we can sort out are rev limiter problem we will be into the 9s and for this season my goal is a 9.5sec run.
audi man
Postby audi man » Mon Mar 16, 2009 10:24 am
Lith wrote:Nice work man, good seeing this getting some sharp times! Is that still on pump gas?
yes still running 98 pump gas.
audi man
Postby Prymal » Mon Mar 16, 2009 11:11 am
lighten her up , tweak the rev limiter , and hopefully she'll be a 9.5sec street driven brawler !
Aweome news for toyota followers in NZ , when we have cars like this sticking it to V8's
Prymal
Postby Lith » Mon Mar 16, 2009 11:20 am
Thats nuts, well done! Is there any Nitrous Oxide usage?
Lith
Postby audi man » Mon Mar 16, 2009 11:22 am
No nos yet but when the rev limiter fixed then the nos will be used :lol:
audi man
Postby Lith » Mon Mar 16, 2009 11:41 am
Top effort, well done. I think Croydens were on race gas? I'm not sure if there are any 9s "imports" in NZ running pump fuel...
Lith
Postby Snaps » Mon Mar 16, 2009 1:48 pm
Wow, awesome job.... get it on some race gas and remove the rev limiter, then it should go a lot faster!
Cheers,
Brandon
2000 ZZT231 Manual Toyota Celica
Snaps
Postby 1I1 » Mon Mar 16, 2009 1:53 pm
Snaps wrote: remove the rev limiter
Maybe not such a good idea :wink:
Definately will be good to see another 9sec toyota!
TRD Clicky >>Here
1I1
Postby the fallen303 » Mon Mar 16, 2009 3:30 pm
what diff you running john? can probably raise the limiter another 500-1k, but that wouldn't gain you that much by the end of the track, and if you're already hitting it as it is, by the time you use nos as well, just raising the limiter may not help you enough.
true house of JZ
Stay true to the origin
the fallen303
Postby deaf_rattle » Mon Mar 16, 2009 3:47 pm
diet or transplant time
Postby 1hypo3 » Mon Mar 16, 2009 4:26 pm
Change your diff ratio and then use the nos to compensate, then you would be in the 140s mph maybe hit 150 8)
1hypo3
Postby audi man » Mon Mar 16, 2009 4:33 pm
1hypo3 wrote:Change your diff ratio and then use the nos to compensate, then you would be in the 140s mph maybe hit 150 8)
My car already max out at about 145mph and it was like hitting a brick wall thats why it was dropping my speed any were from 130mph up to 138mph i need to get around 155mph, looking at my half track speed that was 119mph i should been close to 150mph.
audi man
Postby audi man » Mon Mar 16, 2009 4:35 pm
the fallen303 wrote:what diff you running john? can probably raise the limiter another 500-1k, but that wouldn't gain you that much by the end of the track, and if you're already hitting it as it is, by the time you use nos as well, just raising the limiter may not help you enough.
The diff i am running is a 3.7 and i cannot find a supra diff lower than that.
audi man
