ae92 gtz common problems?????
Postby jakesae101 » Wed Mar 18, 2009 10:33 pm
im looking at one of these as a swap for my notchback ae85 any common issues/areas i should look for issues?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Mr Revhead » Wed Mar 18, 2009 10:37 pm
well, just all the usual old thrashed car things....
and stuffed ICV. you'll spot that easy as it will be surging at idle
and noisy supercharger
Postby Dell'Orto » Wed Mar 18, 2009 10:38 pm
They're FWD, its a common failing amongst modern Toyotas ;) :lol:
Other than that, they're pretty solid, just look for the usual wear and tear type things.
Postby escortman » Thu Mar 19, 2009 6:48 am
yeh makesure its boosting the right amount for that model
4x4 toyota blizzard offroader
escortman
Postby ~SlideWays~ » Thu Mar 19, 2009 8:59 am
pre-89 look for rust in rear parcel shelf (pull up carpet and stick you head in the boot), top of windscreen and around rear lights.
Could be AFM or MAP.
Ask about fuel consumption. They can use a whole tank for 250k's normal driving if oxygen sensor or knocksensor is stuffed (both Dstrb and I have had this issue).
2nd and 3rd gear syncro's.
~SlideWays~
Postby jakesae101 » Thu Mar 19, 2009 9:42 am
thats for that alas they do suffer from fwd how fast are these things in stock trim? how much boost is standard?
jakesae101
Postby ~SlideWays~ » Thu Mar 19, 2009 10:08 am
jakesae101 wrote:thats for that alas they do suffer from fwd how fast are these things in stock trim? how much boost is standard?
They make around 100kw-110kw's atw, but torque is the real winner. Depends if AFM or MAP.
Not sure on standard boost. Mine has never been standard :lol: EDIT: but probably about 8psi.
FWD is not a problem, good suspension and decent tyres will make even a non lsd one perform well.
I used to have a modified MAP 4agze AE86 and I have more fun driving my Turbo GTZ even if it is FWD :wink:
~SlideWays~
Postby rollaholic » Thu Mar 19, 2009 10:38 am
have seen a few rust around the boot as well, under the rubber seal. well worth lifting that for a look.
they feel fast-ish but they arent, and single spinner is ftl.
Postby jakesae101 » Thu Mar 19, 2009 10:48 am
better with a 14psi pulley kit on them?
jakesae101
Postby Mr Revhead » Thu Mar 19, 2009 10:53 am
oh yeah rust under rear screen and parcel shelf
open the boot and look up under the rerar screen
also around rear tail lamps
Postby Mr Revhead » Thu Mar 19, 2009 10:54 am
and also on some check for wet front carpets, sign of rusting out of the innder guard where the runoff from the cowl drips
Postby ~SlideWays~ » Thu Mar 19, 2009 11:39 am
Mr Revhead wrote:oh yeah rust under rear screen and parcel shelf
Is there an echo in here? :lol: :wink:
~SlideWays~
Postby ~SlideWays~ » Thu Mar 19, 2009 11:40 am
jakesae101 wrote:better with a 14psi pulley kit on them?
Sure.
~SlideWays~
Postby Quirky » Fri Mar 20, 2009 4:41 pm
Mr Revhead wrote:and noisy supercharger
My supercharger clatters a lot when its not at full boost.
It sounds like a bad sound. Is this a sign of a wearing supercharger?
The supercharger oil is full, and its of a clear colour.
Hello There
Quirky
Postby levinguy » Fri Mar 20, 2009 5:48 pm
could be the clutch?
edit: clutch that engages the supercharger that is
levinguy
Postby Quirky » Fri Mar 20, 2009 6:18 pm
Does it mean that my Corolla needs a new s/c clutch soon?
You can definitely feel it when it bites.
Its also a bit annoying cause my engine mounts are a bit worn, so it shakes quite abit when its engaging/dissengaging
Hello There
Quirky
Postby jakesae101 » Mon Mar 23, 2009 8:51 pm
well i got it and my god is it goood to have some power again after a 3au need bigger wheels (on steelies) and they just light up way to easy and lsd box mmmm so good
jakesae101
Postby rollaholic » Mon Mar 23, 2009 10:01 pm
im pretty sure AE92s dont have LSDs
Postby jakesae101 » Mon Mar 23, 2009 10:39 pm
feels like one to me or some epic torque steer
jakesae101
Postby Mr Revhead » Mon Mar 23, 2009 10:42 pm
AE92s never had LSD stock
Users browsing this forum: Bing [Bot] and 25 guests
