lacking in 4age know how...
Postby trd_chik » Thu Apr 16, 2009 9:43 pm
wondering if anyone knows what gearbox a 20v 4age usually has (i should kno lol but i dont!!!)
as im possibly getting a levin off a friend but it needs a new gearbox.
trying to gauge an idea of what they are worth to see if its worth the hassle.
comments welcome :)
trd_chik
Postby loose_unit » Thu Apr 16, 2009 9:48 pm
Silvertop c52, facelift had a c56.
Blacktop 5 speed is c56 and 6 speed c160?
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby rollaholic » Thu Apr 16, 2009 10:02 pm
c52s are pretty cheap!
Postby dnalunchie » Fri Apr 17, 2009 11:04 am
rollaholic wrote:c52s are pretty cheap!
what about the gtz box? i know their the pick of the bunch for strength but i heard sumwhere that the ones in the super charged mr2's was slightly better and is pretty much the same box? just with stronger gear set?
Current: 90 3sfe Corona
dnalunchie
Postby ~SlideWays~ » Fri Apr 17, 2009 11:08 am
Yes they are strong but the gears are way too long for a 4age, it would sap the life out of it. They need short ratio gears.
4agze = E51/E58
~SlideWays~
Postby Mr Revhead » Fri Apr 17, 2009 11:39 am
loose_unit is correct
gtzs use e serioes box, very different. and very wrong for n/a
Postby trd_chik » Fri Apr 17, 2009 1:32 pm
thankies 4 the info guys, been very helpful :)
if anyone in CHCH has a c52 gearbox they want to sell feel free to post up too.
ta
trd_chik
Postby rollaholic » Fri Apr 17, 2009 1:41 pm
E series boxes got used in the celicas and so on too. i believe the mr2 ones need some fiddling with shifter linkages etc but someone else will be able to confirm that.
but as rev noted not suitable for NA 4ages, the jump from 2nd to 3rd in particular is big. plus they are heaps heavier than C boxes
Postby Alex B » Fri Apr 17, 2009 2:03 pm
Only the turbo celica/mr2, non turbo are S series, well they are in the SW20/ST182 anyway unsure on others.
