ezy10s wrote:hell yeah mean day! was wondering what you were doing in the dirt!
(i was in the orange carina by the way)
QikStarlie wrote:^ this is the guy you need to punch in the guts for lack of racing room, haha!
i was in the red kp60, awesome day
QikStarlie wrote:nar ezy10's
haha, yeh was having a bit of fun on the hairpin.
thought somthing didnt sound quite right when you were turning the old 1g over, cambelt explains it
ezy10s wrote:Ken maybe, not me though
Bazda wrote:Much damage?
I've been off there backwards but passenger in another car.
So is the engine sweet? how about the brakes? boiled them?
Also how were the slicks?
Bazda wrote:brakes possibly over heated.
When I ran mitex pads they over heated in 3 laps. The pads started coming off the backing plates.
KinLoud wrote:Hunt,
I was in the red 3 door carina. Was doing 1min19ish laps (3sge).
Glenn in the orange 4 door carina was doing 1min11s (1uzV8).
I was following you down the back straight, saw you tap your brakes about 6 times about the kink, then I see you disappearing in a cloud of grass and dust at the hair pin!
As I went around the hairpin I could see you were still the right way up so I didn't stop
I'm a bit puzzled about your left front brakes - I thought it might have been a stuck caliper slider. Having thought about it... stuck slider would usually wear out the inside pad I think.
Pull your brakes to bits and see what the sliders are like.
Maybe the friction material came off the backing plate in one or 2 pieces, this could explain why the pedal went long on you.
Can't find it on my video sorry, think the battery went flat during that session.
Ken
cat007 wrote:Bazda wrote:brakes possibly over heated.
What pads are you running now?
mjrstar wrote:other reports i have say the green machine was having a decent battle with a mad-man in an integra.
cam timing in the 1g's isn't pretty easy... not a lot of info on it but i used some the details from a 7m off the internets..
the only problem with mine is i have to lift the engine out a bit to get the front pulley off...
I can confirm that a lighweight body makes a 1g go well.
Outbraking a fraser... well maybe this wasn't the best idea..
good to hear no major damage!!!
