Track day Pukekohe 1st June
Postby Bazda » Tue Apr 21, 2009 11:01 am
Re: Track day Pukekohe 1st June
Postby cat007 » Tue Apr 21, 2009 11:14 am
Bazda wrote:http://nzhondas.com/forum/upper-north-island/91348-1st-june-queens-birthday-pukekohe-track-day.html
I'm in - will register and pre-pay asap
I forgot I was an NZHonda's member from way back lol
Postby Bazda » Tue Apr 21, 2009 11:34 am
I'll register and pay once I get my car run and and tuned with the new turbo.
Also to fix my oil pump issues, but have plenty of time before this track day.
I dont want to miss another one!! + these ones have some mean cars!! last time there was an R35 doing 1.06s.
Postby cat007 » Tue Apr 21, 2009 12:37 pm
Bazda wrote:I'll register and pay once I get my car run and and tuned with the new turbo.
No no you're doing it wrong. You're supposed to per pay without your car going so you get motivated to get your car goin. Like me :)
Postby cat007 » Wed Apr 29, 2009 8:58 am
Registered yet?
I'm starting to panic - with just on 1 month to go, I haven't even got my rotors let alone caliper brackets made. Plus I need to make some heat shields for my brake master cylinder.... :lol:
Postby Bazda » Wed Apr 29, 2009 9:44 am
Registered yet?
umm i've still got to run in my engine fully, should be done this weekend with a drive down to hamilton, then dyno tune is next saturday.
Also gota fix my oil pump issues (that should be done by next week before the dyno tune)
After that gona install a half cage the weekend after, so gives me 1 week left free to do some mucking around with wheel alignments, painting cage, making up spare drive shafts etc.
I'll pay only after its run in and put on the dyno.
Postby cat007 » Wed Apr 29, 2009 9:51 am
Bazda wrote:umm i've still got to run in my engine fully, should be done this weekend with a drive down to hamilton, then dyno tune is next saturday.
What the? Spare driveshafts? HAHA - most people take spare brake pads, fluids and tyres - but spare driveshafts just sounds funny....although maybe I should've taken a spare cambelt last time :P
I hope you get everything done man - I'd like to see your car going round the track and past me :)
Postby Bazda » Wed Apr 29, 2009 10:10 am
Car has a habit of F****ing up inner CVs on the track. I grease them with Redline CV grease which makes them last alot longer than normal cv grease. Also tends to split the boots often. Really annoying! I need to find some better boots made from some sort of fibre or something, not just cheap rubber.
You wont see me pass you, will just be a blur on your incar camera :D
Postby cat007 » Wed Apr 29, 2009 10:29 am
That is pretty strange that your CV boots fail - as I wouldn't have thought there'd be any more stress on the boot than a lower powered car?
haha - yeah yeah - just because you're 100kw more and 400kg less :P
Postby postfach » Wed Apr 29, 2009 10:36 am
Heat + centrifugal force on grease at high speed = busted boots?
postfach
Postby Bazda » Wed Apr 29, 2009 11:29 am
postfach wrote:Heat + centrifugal force on grease at high speed = busted boots?
Yes thats what I think it is. I actually install a split pin under neath the boot before I clamp it on. To re leave some pressure on the inside. Def helps alot.
Postby Bazda » Wed Apr 29, 2009 11:30 am
I think my gearbox must generate lots of heat with the power. transfers it to the input CV. + the torque out of the corners from a turbo engine.
Pff no way do I use 330kw at the track! lol.
I use 15-19psi so around 240-280kw
Postby cat007 » Wed Apr 29, 2009 11:32 am
Don't understand that....
Postby cat007 » Wed Apr 29, 2009 11:34 am
Ok so still more power than me and a lot less weight lol - dam you :P
you should have an over/high boost function for halfway down the front and back straights :) :)
Postby Bazda » Wed Apr 29, 2009 12:47 pm
Provides a breathing gap for the CV boot. Between the shaft and where you clamp over the boot.
Postby Bazda » Wed Apr 29, 2009 12:48 pm
Think i'm already going fast enough lol + I hit the limiter in 5th couple hundred meters before the 200m sign on the back straight.
Postby postfach » Wed Apr 29, 2009 1:07 pm
Do you ever split the boots on the dyno? It would be interesting to put a camera under the car during a dyno run and see how much the cv boots actually expand at high speed.
postfach
Postby Bazda » Wed Apr 29, 2009 1:43 pm
postfach wrote:Do you ever split the boots on the dyno? It would be interesting to put a camera under the car during a dyno run and see how much the cv boots actually expand at high speed.
Never split any at the drags or the dyno. Only ever since I started doing circuit.
Postby cat007 » Wed Apr 29, 2009 1:46 pm
too much full opposite lock over-steer? Stop drifting your FWD hehe :P
Postby Bazda » Wed Apr 29, 2009 4:00 pm
Nah its def lock to lock as I dont use much lock at all on the track.
