Bazda wrote:http://nzhondas.com/forum/upper-north-island/91348-1st-june-queens-birthday-pukekohe-track-day.html
Bazda wrote:I'll register and pay once I get my car run and and tuned with the new turbo.
Also to fix my oil pump issues, but have plenty of time before this track day.
I dont want to miss another one!! + these ones have some mean cars!! last time there was an R35 doing 1.06s.
cat007 wrote:Bazda wrote:I'll register and pay once I get my car run and and tuned with the new turbo.
Registered yet?
I'm starting to panic - with just on 1 month to go, I haven't even got my rotors let alone caliper brackets made. Plus I need to make some heat shields for my brake master cylinder....
Bazda wrote:umm i've still got to run in my engine fully, should be done this weekend with a drive down to hamilton, then dyno tune is next saturday.
Also gota fix my oil pump issues (that should be done by next week before the dyno tune)
After that gona install a half cage the weekend after, so gives me 1 week left free to do some mucking around with wheel alignments, painting cage, making up spare drive shafts etc.
I'll pay only after its run in and put on the dyno.
cat007 wrote:Bazda wrote:umm i've still got to run in my engine fully, should be done this weekend with a drive down to hamilton, then dyno tune is next saturday.
What the? Spare driveshafts? HAHA - most people take spare brake pads, fluids and tyres - but spare driveshafts just sounds funny....although maybe I should've taken a spare cambelt last time
I hope you get everything done man - I'd like to see your car going round the track and past me
Bazda wrote:
Car has a habit of F****ing up inner CVs on the track. I grease them with Redline CV grease which makes them last alot longer than normal cv grease. Also tends to split the boots often. Really annoying! I need to find some better boots made from some sort of fibre or something, not just cheap rubber.
You wont see me pass you, will just be a blur on your incar camera
postfach wrote:Heat + centrifugal force on grease at high speed = busted boots?
That is pretty strange that your CV boots fail - as I wouldn't have thought there'd be any more stress on the boot than a lower powered car?
haha - yeah yeah - just because you're 100kw more and 400kg less
Bazda wrote:
Yes thats what I think it is. I actually install a split pin under neath the boot before I clamp it on. To re leave some pressure on the inside. Def helps alot.
Bazda wrote:
I think my gearbox must generate lots of heat with the power. transfers it to the input CV. + the torque out of the corners from a turbo engine.
Pff no way do I use 330kw at the track! lol.
I use 15-19psi so around 240-280kw
Don't understand that....
Ok so still more power than me and a lot less weight lol - dam you
you should have an over/high boost function for halfway down the front and back straights![]()
postfach wrote:Do you ever split the boots on the dyno? It would be interesting to put a camera under the car during a dyno run and see how much the cv boots actually expand at high speed.
Bazda wrote:
Never split any at the drags or the dyno. Only ever since I started doing circuit.
too much full opposite lock over-steer? Stop drifting your FWD hehe
