Installing 240V inverter in engine bay in Hiace...
Postby cat007 » Mon Jul 13, 2009 12:29 pm
Hey all
The inverter I have is bloody loud and I don't want it in the cabin/van any more.
I'm thinking of mounting it in the engine bay somewhere.
I was thinking of mounting it on the drivers side of the engine bay. Bolting it to the side of what I guess you'd call the wheel arch.
I was going to make, out of alloy sheet, an enclosure for it to stop water splashing on it etc, while still allowing for plenty of air flow.
The only question I have is - should I? I mean, the inverter wont be running while driving around - and I'll be able to stop direct splashes pretty easy and effectively with the enclosure/shield - but what about moisture in the air? That's something I wont be able to avoid and is probably going to be the real killer?
What do people think?
Oh yeah its for the Hiace by the way :)
Postby Bling » Mon Jul 13, 2009 1:02 pm
Unless you go driving in 1m deep puddles I doubt water gets to the top of the engine. So stick it somewhere up that high. Only issue then would be radiant heat from the engine.
Postby Mr.Phreak » Mon Jul 13, 2009 1:03 pm
I wouldn't
Mr.Phreak
Postby cat007 » Mon Jul 13, 2009 1:07 pm
BZG|Bling wrote:Unless you go driving in 1m deep puddles I doubt water gets to the top of the engine. So stick it somewhere up that high. Only issue then would be radiant heat from the engine.
I had a look after driving in that really heavy rain in the weekend. I couldn't see anything wet up high. I was counting on the aluminium box/enclosure on acting like a bit of a heat shield. Although the inverter wont be running while the engine is on (normally) so engine heat shouldn't be a big factor (except for straight after a long drive I suppose?)
Postby cat007 » Mon Jul 13, 2009 1:08 pm
Mr.Phreak wrote:I wouldn't
Because......?
Postby Mr.Phreak » Mon Jul 13, 2009 2:02 pm
It's most likely not designed for it, especially since your other thread has claims of being parked in -5 degree weather.
The reason it's loud is because they get hot, and you're probably aware of what happens to hot things in colder ambient temps
Mr.Phreak
Postby sergei » Mon Jul 13, 2009 3:34 pm
-5 Degrees is fine for a piece of electronics.
What is not fine is 100+ temperature that it will heat soak (when you stop driving and start the unit) and 240V and moisture in there when you start it on cold.
I also think you cannot put it inside closed box as it needs air for cooling.
You could put it in the air filter area under the driver's seat, or battery compartment area, depending how big it is..
Postby cat007 » Mon Jul 13, 2009 3:46 pm
sergei wrote:-5 Degrees is fine for a piece of electronics.
Battery compartment is full of - batteries :P
Air filter area is also filled with, air filter stuff....
I was thinking of making a tunnel type box - so that only the front and rear are exposed as the fans suck from one side through to the other....
Postby matt dunn » Mon Jul 13, 2009 8:34 pm
i wouldn't either.
have seen enough electronic inverters, reducers, cherge equalisers etc damaged due to condensation inside them from exposure to the elements,
even when mounted well up under decks etc out of the way of direct water.
Postby GTCRSHR » Mon Jul 13, 2009 8:38 pm
do you live in a van ?
Nothing to see here ...
GTCRSHR
Postby Mr.Phreak » Mon Jul 13, 2009 10:07 pm
Was more leaning towards the condensation thing (as Matt pointed out)
Mr.Phreak
Postby cat007 » Tue Jul 14, 2009 11:23 am
bugger
I 'really' cant handle it being inside the van - I swear the fans sound like a 747 in the cabin lol
Postby sleeektoy » Tue Jul 14, 2009 11:50 am
In ausie when i had a hiace we had ours in behind one of the panels in the back of the van by the rear wheel arch, wasnt that noisy. Although we had power points in front and rear coming off that mounted to the side panels too. Sparky owned it before us had done a good job, also added a switch/external waterproof plug so we could plug in if it was available and not use the inverter.
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby cat007 » Tue Jul 14, 2009 11:53 am
sleeektoy wrote:In ausie when i had a hiace we had ours in behind one of the panels in the back of the van by the rear wheel arch, wasnt that noisy. Although we had power points in front and rear coming off that mounted to the side panels too. Sparky owned it before us had done a good job, also added a switch/external waterproof plug so we could plug in if it was available and not use the inverter.
hmmm - could do - although, that's where my head will be when watching telly etc....
I might move the inverter around tonight and see where is the quietest while keeping it inside the van....
Postby sergei » Tue Jul 14, 2009 12:30 pm
Have you considered a different inverter?
Postby cat007 » Tue Jul 14, 2009 12:45 pm
I have thought about it. And if I can't find a solution as to where to mount it I might have to look into a better one that has quieter fans
I guess this one was cheap for a reason
Lol
Postby Mr.Phreak » Tue Jul 14, 2009 2:13 pm
cat007 wrote:I guess this one was cheap for a reason
Lol
Is it one of those dodgy plastic ones that the fans run full tit all the time??
Mr.Phreak
Postby cat007 » Tue Jul 14, 2009 2:15 pm
Lol
nah it's metal - this one:
http://www.trademe.co.nz/Trade-Me-Motor ... 879120.htm
Postby cat007 » Tue Jul 14, 2009 5:55 pm
oh and yeah - the fan's run full tit all the time
Postby Scotty » Tue Jul 14, 2009 6:42 pm
If the fans run off 12v could swap them out for some quieter computer ones (they run on 12v) or could wire in a fan controller like this one to reduce the speed of the fans.
Scotty
