BZG|Bling wrote:Unless you go driving in 1m deep puddles I doubt water gets to the top of the engine. So stick it somewhere up that high. Only issue then would be radiant heat from the engine.
sergei wrote:-5 Degrees is fine for a piece of electronics.
What is not fine is 100+ temperature that it will heat soak (when you stop driving and start the unit) and 240V and moisture in there when you start it on cold.
I also think you cannot put it inside closed box as it needs air for cooling.
You could put it in the air filter area under the driver's seat, or battery compartment area, depending how big it is..
Mr.Phreak wrote:sergei wrote:-5 Degrees is fine for a piece of electronics.
Was more leaning towards the condensation thing (as Matt pointed out)
sleeektoy wrote:In ausie when i had a hiace we had ours in behind one of the panels in the back of the van by the rear wheel arch, wasnt that noisy. Although we had power points in front and rear coming off that mounted to the side panels too. Sparky owned it before us had done a good job, also added a switch/external waterproof plug so we could plug in if it was available and not use the inverter.
Mr.Phreak wrote:cat007 wrote:I guess this one was cheap for a reason
Lol
Is it one of those dodgy plastic ones that the fans run full tit all the time??
