SuperStrut suspension specialists in Akl?
Postby benj » Mon Jul 27, 2009 8:11 pm
Hi,
My ST205 has a nasty clunk in the front right suspension. Chances are its the banana arm, however I'm way to much of a muppet to attempt the diagnosis and repair myself.
So can anyone recommend a place that has a good track record with superstrut suspension?
I live in Greenhithe so would prefer somewhere on the shore, but work in town and can get most anywhere in Auckland.
Benj
1997 JDM ST205 - Busted!
2009 Ford Mondeo Diesel
2000 Audi A4 Quattro 2.4
1981 Landrover Series III Diesel
benj
Postby sergei » Mon Jul 27, 2009 9:42 pm
Most unlikely it will be banana arm, It could be the bush in banana arm if certain about location of noise, that item is replaceable, if not from toyota, you could press in an after-market unit.
Most of the clunks come from figure eight and straight arm (big ball joints). To replace all 4 (2 fig 8, 2 straight arms) it will cost you about 750. One banana arm is ~1000...
Postby benj » Mon Jul 27, 2009 10:01 pm
sergei wrote:Most unlikely it will be banana arm.
And of course I meant to say fig 8 (doh!) and hence proving publicly why I should never be trusted to fix anything more complex than a flat tyre.
Benj
benj
Postby soven » Mon Jul 27, 2009 10:05 pm
Try the toyspeed sponsor on the forums for the parts . I remember paying a whole lot less ages ago compared to my local toyota dealer.
soven
noise
Postby ST205 GT4 NZ New Group A » Fri Jul 31, 2009 7:53 am
May be crush tubes are in upside down, they are meant to go in from the top of the subframe not from the bottom, they can give you the clunk noise.
You have had the engine in and out eh, they would have put them in the wrong way,
Cheap fix to put the car on the hoist and check and then drop subframe to install correctly
Check check it my brothova
