Where to drill rotors
Postby doublezero » Thu Nov 19, 2009 11:29 am
Hey guys
I got some blank rotors for my stud conversion but I have not a clue where to get them drilled. Some of my friends said engineering place could do it but they couldn't name one. So if anyone has got their rotors drilled in Auckland, preferably in the East auckland side, please let me know where. and how much they usually cost for a pair of rotors.
doublezero
Postby doin donuts » Thu Nov 19, 2009 4:57 pm
have you tried 0800brakes? they are real good guys
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby atmosports » Thu Nov 19, 2009 5:34 pm
Yeah any good machine shop. Not too sure out East, but cold try Circleline Engineering in Otahuhu as they've done plenty of similar work.
atmosports
Postby doublezero » Fri Nov 20, 2009 8:49 pm
cheers. Will check circleline and Automotive Brake & Clutch out. 0800brakes don't do the drilling unfortunately.
doublezero
Postby Flannelman » Sat Nov 21, 2009 6:14 pm
for good reason. they crack!
Flannelman
formerly known as Affroman
Postby Akane » Sat Nov 21, 2009 6:23 pm
I don't recommend drilling them from blanks.
If you must, get slotted ones, but then even the slotted ones I got from 0800 brakes warped after I did a 200kph+ run, disappointed.
Postby pc » Sat Nov 21, 2009 6:30 pm
I'm assuming he means drilling so that it can slide onto the studs... I think you guys are thinking of drilling for de-gassing.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby matt dunn » Sat Nov 21, 2009 8:41 pm
Brakes warping is usually from incorrcet warm down procedure.
And I would say he is getting the wheel stud holes drilled,
not holes in the brake surface as that would be a recipe for disaster.
Postby Akane » Sun Nov 22, 2009 4:29 am
Uh-oh, my bad :oops:
