Akane wrote:1) Last time I got mine tuned it costed me $800 and they blew the headgasket.
3) the lean trick on low RPM, part throttle tune not just WOT.
ihavelift wrote:turns out i need to leave my car at the shop for a whole day to get the fuel pump checked. WTF???
and can i get a compression test done at a tuning specialist?
ST205 GT4 NZ New Group A wrote:In my humble opinion next step for you is
1. air to air front mount intercooler, -$400-500 ( best mod as it flows a lot better- quicker more response to rev)
2. and then high flow turbo. $800-100 Steve Mirch?? Tsoobs' mate ?
Probably your injectors are max ed out any way ??
Really I would be pretty happy with that power considering that you have a reliable package and have not spent any money on the car having bought it already tuned.
The Power FC in that car was my old one which was already mapped the old owner bought it and had TP put it in and "tune it " I think they charged him $1500 to $2000 interesting as it was already mapped.
But hey you got the bug "chasing the dragon " I know you can't help it but, i couldn't !
ihavelift wrote:Akane wrote:1) Last time I got mine tuned it costed me $800 and they blew the headgasket.
what's the lean trick? and what's the difference between a part throttle tune and WOT? (apart from the obvious)
JustinSpiderholden wrote:I dont understand how going to a front mount on a ST205 is not going to give you better responce or even flow better
As isn't it going to take longer to presureise all the required piping plus filling the intercooler?
You don't see many rally ST205's with front mounts
Akane wrote:ihavelift wrote:Akane wrote:1) Last time I got mine tuned it costed me $800 and they blew the headgasket.
It's called the lean spool trick, any tuner should be able to do that for you. Some tuners only tune for max power, ie: only the load settings under WOT, and they don't care much about part throttle
iOnic wrote:JustinSpiderholden wrote:I dont understand how going to a front mount on a ST205 is not going to give you better responce or even flow better
You don't see many rally cars with front mounts because frount mounted intercoolers are in a compromising position as far as damage goes. Rally cars have a tendency to hit things - generally quite hard too. Top mounts/w2a are used in that situation for reliability more than power/response - you can drive into a tree and complete the stage with only cosmetic damage rather than driving into a tree and losing boost altogether.. Yes they do flow better - they have more volume than the stock system which = less restriction. On the other side of the sword, because of the added volume, response is lost - but not so much that the car is un-drivable - good turbo choice comes into play here. Evo's come with factory front mounted intercoolers and they are some of the most responsive turbocharged cars around...
Yes you can make 250kw (and probably more) with the stock intercooler. But you can just as easily also disconnect the wastegate and have unlimited boost potential - just because it "can" be done doesn't make it a good idea....
®usty wrote:I've seen someone make 250KW with the stock intercooler
JustinSpiderholden wrote:®usty wrote:I've seen someone make 250KW with the stock intercooler
There is nothing wrong with the stock intercooler, for everyday useage
For a street car aiming for less than 250kw there is no point in changing the factory intercooler
Unles you want the wow "Check out that guys front mount comments"
In which case you may was well jsut join the choosen few
