TRD sports thermostat
Postby ®usty » Wed Nov 25, 2009 7:30 pm
Just wanted to get some second opinions
TRD website wrote:By reducing the valve temperature by about 10 to 15ーC compared with that of a standard thermostat, the TRD sports thermostat increases coolant circulation and reduces performance bottlenecks caused by engine heat, to bring out the best in engine performance. (Maintains valve temperature of 71ーC.)
I've heard it increases engine wear on the street, are many people on here running them?
®usty
Postby Crampy » Wed Nov 25, 2009 8:26 pm
Just use a factory Toyota thermostat. Don't use those $hit Tridon ones from Repco though.
Crampy
Postby AE82 FXGT » Wed Nov 25, 2009 8:43 pm
Crampy wrote:Just use a factory Toyota thermostat. Don't use those $hit Tridon ones from Repco though.
Don't use shit Tridon ones from anywhere.
AE82 FXGT
Postby 2jayzgte » Wed Nov 25, 2009 8:50 pm
I'm a fan I have run this TRD Thermostat in my Supra for years open road water temps run at about a 1/4 to a 1/3 in comparison to the factory my cars water temp used to run at about 1/2 on the water temp gauge.At the track though water temps are dead steady at between a 1/3 and 1/2 on the water temp gauge.
2jayzgte
Postby Crampy » Wed Nov 25, 2009 9:00 pm
That's fine for a car that's going to go out on a track, but for a road car stick to the stock temp.
A colder car uses more gas. Leave it at the normal (factory) operating temp.
Crampy
Postby Elmo » Wed Nov 25, 2009 9:21 pm
Crampy wrote:That's fine for a car that's going to go out on a track, but for a road car stick to the stock temp.
x2
Elmo
Postby ®usty » Wed Nov 25, 2009 9:22 pm
yea thats I kind of though, thanks for your input
®usty
Postby rollaholic » Wed Nov 25, 2009 10:41 pm
2jayzgte wrote:I'm a fan I have run this TRD Thermostat in my Supra for years open road water temps run at about a 1/4 to a 1/3 in comparison to the factory my cars water temp used to run at about 1/2 on the water temp gauge.At the track though water temps are dead steady at between a 1/3 and 1/2 on the water temp gauge.
with the money invested in your car i'd have thought anything less than half would be worrying you, forget about gas costs cold engines wear faster!
Postby NILPSI » Wed Nov 25, 2009 10:53 pm
I had one in the Trueno
Had it in for about 2 weeks then took it out, car never got off auto choke because it never warmed up enough, fuel use was stupid, 250kms per tank with it to 450kms per tank with stock temp
Its now sitting in my hall cupboard being useless, glad i didnt pay anything for it
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
NILPSI
Postby matt dunn » Wed Nov 25, 2009 11:05 pm
NILPSI wrote:I had one in the Trueno
Sounds like you need to sell it to me then.
Postby Akane » Thu Nov 26, 2009 12:28 am
You'll need an aftermarket ECU with water temp fuel compenstation adjustment to use one of these thermostats, or else it'll never get out of cold temp fuel compensation.
To my understanding these thermostats help to prevent potential steaming of certain hot spots of the engine?
Certainly don't need one unless you are laying down some decent power.
Postby iOnic » Thu Nov 26, 2009 12:36 am
Dunno why people install these into road cars. The only thing they achieve is poor fuel consumption and premature engine wear :? As Akane said, you can't reap the benefits of having one without an aftermarket ECU and tune and even then they're not ideal for road driven cars.
Postby 2jayzgte » Thu Nov 26, 2009 7:12 am
Poor fuel consumption well I do have a HKS F-Con V Pro in my car and fuel mileage on a full tank has increased by about 50-60 km on a full tank.I got from my front door in Douglas St in Wgtn to 1/2 way between Wairoa and Gisborne and thats when the fuel light came on thats the furtherest I've ever got on a full tank.
2jayzgte
Postby NILPSI » Thu Nov 26, 2009 9:33 pm
Make me an offer, since it doesnt say TRD on it anywhere ill put it back in the box for you too :P
NILPSI
