What does a mitsi tach interface look like?
Postby thegreatestben » Sun Feb 28, 2010 7:42 pm
Apparently I need one to get my tachometer in the mr2 to work with the link.
What does it look like and where in the car is it located?
thegreatestben
Postby 3T-Rona » Sun Feb 28, 2010 7:55 pm
on the coil/ignitor bracket, on older galants, got a few if u want me to dig one out
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby thegreatestben » Sun Feb 28, 2010 8:11 pm
Hmm, must be on the coil bracket on the galant I pinched the ignitor and bracket from. Can you take a pic of one for me?
I'll just go get one from pick a part.
thegreatestben
Postby Bazda » Sun Feb 28, 2010 8:55 pm
Its a little square black plastic box, says Interface on it, or tacho, one of those I cant remember. About 40mmx40mm
Postby thegreatestben » Sun Feb 28, 2010 8:59 pm
Do I connect that to the tach wire on the ignitor, then from the interface to the ign wire?
thegreatestben
Postby Bazda » Sun Feb 28, 2010 9:02 pm
The interface has 2 input wires and 1 output.
They are designed to run with twin coil setups, so each 2x '-'ve off the coils to the interface 'in' I think its labelled, then 'out' to tacho '-'ve
Postby thegreatestben » Sun Feb 28, 2010 9:20 pm
Oh ok, Just I am using mitsi twin post coils and matching ignitor.
And the ignitor has:
IB1
IB1
OC1
OC2
12v in
GND
Tach
Seems strange it would have a tach wire and then just use the -ve signals?
thegreatestben
Postby matt dunn » Sun Feb 28, 2010 9:35 pm
thegreatestben wrote:Oh ok, Just I am using mitsi twin post coils and matching ignitor.
IB1
IB1
OC1
OC2
12v in
GND
Tach
That igniter has the tacho interface built into it
the GND will be earthed to make the igniter part work
Feed ign 12V +ve to the 12v in and you will get the correct signal out of the tach terminal to drive a normla coil -ve driven tacho.
Postby thegreatestben » Sun Feb 28, 2010 9:41 pm
Mad.
Seems like I just need to connect one wire in that case.
My face right now :D
thegreatestben
