"Intercooler Tubes"
"Intercooler Tubes"
Postby ee904age » Thu Mar 18, 2010 7:29 pm
This may have been posted before, but does anyone have any experience with these?
Any Pros/Cons?
Seem like a great idea in theory for the likes of MR2's bt possibly a big airflow restriction?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby cogent » Thu Mar 18, 2010 7:32 pm
it's just a compact water to air IC, isnt it?
cogent
Postby sergei » Thu Mar 18, 2010 7:37 pm
Sounds like scam to me.
Not enough of volume water flows to take all the heat away.
Simple physics as a matter of fact. Even discarding the low efficiency of fins, and added drag. There is not even enough surface for heat transfer to water jacket. Unless you are spraying it with liquid nitrogen I don't see how it would work at all.
Postby Akane » Thu Mar 18, 2010 8:58 pm
Looks like it works, and you can have a lot of them to replace your normal pipes, might work friggin awesome on something with very little room, like the MR2
Postby matt dunn » Thu Mar 18, 2010 10:37 pm
we have a large one for the MRS we are building.
I believe they will work, and data logging and inlet temp sensors will prove it either way.
Water cools a lot better than air,
Postby Stott69 » Sat Mar 20, 2010 11:55 am
Could hook it up via the air con with a temp sensor, when you see the gauge rise hit air con and blast it on full chill. shame the air con will drain all the power your gaining tho
Image jzs147 Aristo money pit
Stott69
Postby Boosted_162 » Sat Mar 20, 2010 2:18 pm
matt dunn wrote:we have a large one for the MRS we are building.
Very keen to hear your results when its running :D
Postby wishihadaTE27 » Sat Mar 20, 2010 6:36 pm
water has a heat capacity something like 4 times better than air - so its definitely possible.
wishihadaTE27
Postby mr_monkey » Sat Mar 20, 2010 9:22 pm
the tubes are very very very expensive compared to other water 2 air intercoolers on the market.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby sergei » Sat Mar 20, 2010 11:49 pm
Has any one considered amount of energy needed to dissipate vs surface area and water volume?
There is a reason why intercoolers are bulky, even W/A ones that are generally smaller still, have huge surface area where water indirectly contacts the air flow.
That ring, even if you put 10 of them, hasn't got enough surface area to allow efficient heat transfer. The fins do not have capacity to conduct heat either. They are long and thin.
I can bring calculations into this... but I am too lazy.
Here is the basic break down:
Water heat capacity is ~4.2 kj/ kg K
In other words it means that 4.2kJ needed to raise temperature of 1kg (1L) of water by 1K (1'C).
Now lets assume following things: guestimate % of heat lost through turbo is ~10% of the power. So if 200kW engine 20kW is heat created by turbo.
20kW is 20kJ per second.
I assume the following: temperature drop is 30'C (before intercooler is 80'C, after is 50'C).
so we have the following numbers:
4.2 kJ / kg K
30K
20kJ / s
We can calculate water flow needed to soak that heat.
20kW / (30K * 4.2 kJ / kg K) = 0.159 kg / s (or ~9L/min).
That is all good and dandy, until you start calculating the capacity of certain area to conduct heat. What people expect is all of those 20kW go through that small area (~10sq cm). The smaller the surface the greater thermal resistance. Thermal resistance of that desing is huge.
Thermal conductivity of aluminium is: 237 W/ mK
The thickness of that unit (eyeballing) is ~ 5mm. The area ~ 10sq cm
So:
237 W/ mK * 30K * 0.001sq m / 0.005m =1420 Watts.
This unit with those parameters (temp difference is 30K and dimensions eyeballed from picture, you are welcome to supply real dimensions), the unit can only dissipate 1.42 kWatts!. That number is irrelevant as the fins are not able to conduct that heat to the rings anyway (same reason - low thermal conductivity).
To improve my calculations one can measure real dimensions (I need surface area of the area covered by ring and thickness of the tube wall).
Postby 20v_rollaboy » Sun Mar 21, 2010 12:40 am
My jetski comes with a tube type intercooler which is actually built into the intake manifold.
One of the best mods to do to these is swap it out for an external w2a intercooler because of the surface area.
20v_rollaboy
Postby cat007 » Sun Mar 21, 2010 10:12 pm
20v_rollaboy wrote:My jetski comes with a tube type intercooler
wait wait wait wait wait waaaaaaaaait a minute
You own a turbo jetski? Is that normal? 8O
Postby Bling » Sun Mar 21, 2010 10:20 pm
Some come super charged factory, and they go quite well if I do say so :lol: So his is either supercharged, or he's slapped a turbo on it :lol: What mods have you done to get 74mph out of it? What they do normally, 65?
Postby 20v_rollaboy » Sun Mar 21, 2010 10:56 pm
Yes super-charged :D
Out of the box around 65 yes. Quite a bit done to mine, might start up a project thread if people are interested :?:
20v_rollaboy
Postby Bling » Sun Mar 21, 2010 11:02 pm
Do it!
Postby loudstealthGT-Four » Sun Mar 21, 2010 11:21 pm
BZG|Bling wrote:Do it!
+1
loudstealthGT-Four
Postby cat007 » Mon Mar 22, 2010 7:12 am
+1
++1 :)
Postby sergei » Mon Mar 22, 2010 9:00 am
20v_rollaboy wrote:My jetski comes with a tube type intercooler which is actually built into the intake manifold.
This is very different to the tubes in question.
The water core is inside, and has much greater surface area and volume. Also if you look at the fittings, it supports much higher water flow.
Postby Adamal » Mon Mar 22, 2010 9:06 am
20v_rollaboy wrote:Yes super-charged :D
Twin charge it! :D
