Building NZ's Fastest st206 Curren
Postby chrisarmo86 » Fri Mar 19, 2010 9:36 pm
Basically I am looking for any info on NZ's fastest/ most powerful toyota curren. Cant seem to find anything on the net about the curren at all. I know infinti has a turbo one, but I want an official E.T/dyno plot to go by.
Over the next 6 to 12 months I am going to give my st206 the boost treatment. Im hoping to finish up with a 200kw atw fwd on factory internals.
Anyone got any advice, or insights? Would love to make this a reality
My engine wants to be a 3SGTE when it grows up
chrisarmo86
Postby Dell'Orto » Fri Mar 19, 2010 9:50 pm
Take it to the strip now, you win instantly :lol:
Postby chrisarmo86 » Fri Mar 19, 2010 10:22 pm
lolz thats what I thought. Does anyone know how safe id be running no more than 4-6psi through a T28 on my stock internal 3sge?
I can get the turbo gear quite cheap and i will be fabricating all the manifold/ IC plumbing, so im goin to do a conservative budget build while i build up a forgied 3sgte over winter
chrisarmo86
Postby Dell'Orto » Fri Mar 19, 2010 10:26 pm
Should be alright, though you'll need a different ECU to do it.
Postby chrisarmo86 » Fri Mar 19, 2010 10:31 pm
explain....?
chrisarmo86
Postby Sick Puppy » Fri Mar 19, 2010 10:34 pm
Slightytwisted turbo'ed his FWD Celica, and I'm pretty sure Infinite was going to or did the same with his Curren. They should be able to provide you with heaps of advice, but be warned- it's expensive to do, you'll lose lots of traction (as in tyres) and did I mention you'll spend lots of $?
You'd be better off (and I really hate to say this, really I do) buying a GT4 and putting up with the fuglyness of it [puts flame suit on], or putting the Curren front end on like they do in the states.
I was contemplating modifying the back end of my Curren years back by grafting the floor pan of a GT4, but then for the $ involved, and it still wouldn't have the same abilities as a stock GT4... nah. :( my 2c anyway.
Up to you, your money, good luck!
Project thread here
Discussion thread here
Sick Puppy
Postby iOnic » Fri Mar 19, 2010 10:47 pm
Just put a 3SGTE in it. An unopened [non caldina] 3SGTE + a few bolt ons will happily make a reliable 200wkw without breaking a sweat.
Postby chrisarmo86 » Fri Mar 19, 2010 10:53 pm
any reason it cant be a caldina motor? thats all I seem to find on tardme
chrisarmo86
Postby 2jayzgte » Fri Mar 19, 2010 11:48 pm
I no this is different but all toyota's were'nt built with FAST being the operative word.Please don't take offence.
2jayzgte
Postby chrisarmo86 » Fri Mar 19, 2010 11:55 pm
point taken but my curren isnt slow by any means. People modify 6th gen 3sge celicas dont they :roll:
chrisarmo86
Postby Akane » Sat Mar 20, 2010 2:49 am
Gen 3 3S-GTE from ST205
TD06SH-20G
Profit!!!
Postby MR2BOY23 » Sat Mar 20, 2010 9:36 am
Akane wrote:Gen 3 3S-GTE from ST205
TD06SH-20G
Profit!!!
Haha
this!
MR2BOY23
Re: Building NZ's Fastest st206 Curren
Postby mr30%jr » Sat Mar 20, 2010 10:35 am
chrisarmo86 wrote:.
Im hoping to finish up with a broken curren
No
just no
go buy a st205 gtfour.... wow it allready has a turbo motor. :lol:
mr30%jr
Postby celica_xr9145 » Sat Mar 20, 2010 10:42 am
as said, drop in a late model 3SGTE and your away. Probably easier, cheaper and more reliable than turboing a 3SGE.
Does your curren have the factory LSD trans?
celica_xr9145
Postby ®usty » Sat Mar 20, 2010 11:14 am
some ST204 are getting FWD 250kw, also might be a good idea to run an mr2 lsd gearbox (and convert the linkages to fwd) better gear ratios for boosting than the S54 your running now
®usty
Postby eskimo » Sat Mar 20, 2010 12:50 pm
celica_xr9145 wrote:as said, drop in a late model 3SGTE and your away. Probably easier, cheaper and more reliable than turboing a 3SGE.
Id agree, not much point spending cash on a turbo conversion for the standard 3sge if you just going to drop it out and replace it with a 3sgte after winter.
Leave the car standard and spend the cash on the 3sgte you want to build. Do it once do it right i say
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby CelicaGT8 » Sat Mar 20, 2010 3:11 pm
Do it once, do it right, look at my corona on the link below, it started off 3sge + t, terrible things happend
CelicaGT8
Postby ®usty » Sat Mar 20, 2010 3:56 pm
or you could build an agressive NA 3S-GE :twisted:
®usty
Postby Al » Sat Mar 20, 2010 4:36 pm
®usty wrote:or you could build an agressive NA 3S-GE :twisted:
Spend 10x as much for half the performance :P
Al
Postby Quirky » Sat Mar 20, 2010 5:02 pm
200kw doesnt seem that much.
Im making 180kw atw with gt28r on 17psi of boost.
I need a bigger turbo, im sure the tiny 28r is pumping hot air.
Hello There
Quirky
