metal_sean_head wrote:yeah was thinking sway bars. Also do rear strut braces do alot? ive got a factory front one which im inclined to upgrade. And also for the front one, am i correct in saying one which goes from the strut towers to the firewall are better?
I guess my main question was should i modify my red top now? with usual bits, exhaust, intake? or do everything else sorta first and then see where my engines at. i just don't want it to blow up after doing a spending a bit on it, replace it and have to do it again. you know? might be un avoidable though
B1NZ wrote:also a whiteline adjustable rear sway bar is good bang for buck and removed the factory understeer issues
Dell'Orto wrote:B1NZ wrote:also a whiteline adjustable rear sway bar is good bang for buck and removed the factory understeer issues
You could do worse than read the posts in your thread...
Users browsing this forum: Bing [Bot] and 3 guests
