DRFTIN wrote:but if you want to be able to put out a fire bigger than a match stick then the bigger the better
yes. have done this many times in order for street cars to comply without them drilling holes in their car , in fact is probably stronger than bolting through floor if designed correctly.1I1 wrote:Sorry to go a little OT. Does the bracket that the fire extinguisher is held in have to be bolted directly to the floor? Can i have a bracket that utilizes the seat mounting bolts then have the extinguisher bracket bolt to that?
just make sure it dosn't foul the seat adjuster1I1 wrote:Sweet, saw this design on a car in a magazine and thought it was a brilliant idea!
fangsport wrote:just make sure it dosn't foul the seat adjuster1I1 wrote:Sweet, saw this design on a car in a magazine and thought it was a brilliant idea!
andrewgreen1000 wrote:I have a 1kg extinguisher for Superexpensive in the garage with the metal mounting bracket that i was going to mount in my car in case of track days etc, and was just going to drill a hole in my floor and put sum decent bolts and washers+nuts. But I wasn't sure if this was legal or not, doesn't seem right drilling through the floor. is the WOF man going to pull me up for it?
And also wheres good to go get sum bolts nuts that would be suitable?
B1NZ wrote:just make sure you use 8mm bolts with panel washers on the underside with either nylock nuts or 2 locking nuts.
And be careful not to drill through your fuel and/or brake lines![]()
