Fire Extinguisher
Fire Extinguisher
Postby Barark » Fri Apr 30, 2010 12:17 pm
My project this weekend is to find and mount a proper Extinguisher, help comments is very helpful!
Ok so what does everyone use in their cars for fire extinguishers?
-Powder or Foam
-1kg 2kg 5kg ect
-Where have you mounted it?
Thanks Everyone, Barark.
Barark
Postby DexGT » Fri Apr 30, 2010 1:45 pm
For motorsport use a A:B:E (powder) 1Kg model WITH a metal bracket. I believe mitre ten had suitable ones for $30ish . Look for the one with "CAMS approved " on it as these have the proper mounting bracket .
DexGT
Postby Truenotch » Fri Apr 30, 2010 1:50 pm
I always mount mine in the passengers foot well, with 2 10mm bolts going through the floor and a big washer + nylock nut on the bottom. It's quick and easy.
Truenotch
Postby DRFTIN » Fri Apr 30, 2010 2:01 pm
but if you want to be able to put out a fire bigger than a match stick then the bigger the better
DRFTIN
Postby pureadrenalin » Fri Apr 30, 2010 2:19 pm
DRFTIN wrote:but if you want to be able to put out a fire bigger than a match stick then the bigger the better
Amen
pureadrenalin
Postby Truenotch » Fri Apr 30, 2010 3:10 pm
Agreed. I've got a 2kg Wormald one... They cost more but are worth it if you're doing a bit of track work. Especially if the trackdays you're doing are run by independent people without all the gear.
Truenotch
Postby B1NZ » Fri Apr 30, 2010 6:18 pm
Have a look here, I got a 2KG ABE with metal bracket for about $70+ GST +$10 shipping:
http://www.newzealandfireextinguishers.co.nz/
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Snoozin » Mon May 03, 2010 9:11 pm
PM me if you like OP, I work in safety so extinguishers etc are my gig :)
Snoozin
Postby fangsport » Mon May 03, 2010 9:39 pm
2kg mounted in front of drivers seat across the car.
.9kg mounted longways in front of gear lever so passenger has something solid to throw at me!! should really put this one in front of passenger seat to make it easier for him/her to reach!!!!!
fangsport
Postby 1I1 » Mon May 03, 2010 9:42 pm
Sorry to go a little OT. Does the bracket that the fire extinguisher is held in have to be bolted directly to the floor? Can i have a bracket that utilizes the seat mounting bolts then have the extinguisher bracket bolt to that?
TRD Clicky >>Here
1I1
Postby fangsport » Mon May 03, 2010 9:50 pm
1I1 wrote:Sorry to go a little OT. Does the bracket that the fire extinguisher is held in have to be bolted directly to the floor? Can i have a bracket that utilizes the seat mounting bolts then have the extinguisher bracket bolt to that?
yes. have done this many times in order for street cars to comply without them drilling holes in their car , in fact is probably stronger than bolting through floor if designed correctly.
fangsport
Postby 1I1 » Mon May 03, 2010 9:51 pm
Sweet, saw this design on a car in a magazine and thought it was a brilliant idea!
TRD Clicky >>Here
1I1
Postby fangsport » Mon May 03, 2010 10:02 pm
1I1 wrote:Sweet, saw this design on a car in a magazine and thought it was a brilliant idea!
just make sure it dosn't foul the seat adjuster
fangsport
Postby NILPSI » Mon May 03, 2010 11:41 pm
I did this to mount the extinguisher in the Supra for the megameet trackday in 07, not much room under those seats so couldnt move the seat forward for the above mentioned reason.
Corolla should be fine though, had the Trueno one mounted infront of the drivers seat for ages with no issues
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
NILPSI
Postby andrewgreen1000 » Mon May 03, 2010 11:52 pm
I have a 1kg extinguisher for Superexpensive in the garage with the metal mounting bracket that i was going to mount in my car in case of track days etc, and was just going to drill a hole in my floor and put sum decent bolts and washers+nuts. But I wasn't sure if this was legal or not, doesn't seem right drilling through the floor. is the WOF man going to pull me up for it?
And also wheres good to go get sum bolts nuts that would be suitable?
Current: '99 Ae111 Sprinter GT, '12 Aqua
Gone, but not forgotten: '81 KP Starlet, '92 Ae101 Truneo, '97 BZ-Touring Carib, '96 LWB Bighorn, '96 Bogan mobile Levin.
andrewgreen1000
Postby Snoozin » Mon May 03, 2010 11:56 pm
Remind me to show you mine in the Torneo on Wednesday.
Snoozin
Postby Snaps » Wed May 05, 2010 1:12 am
andrewgreen1000 wrote:I have a 1kg extinguisher for Superexpensive in the garage with the metal mounting bracket that i was going to mount in my car in case of track days etc, and was just going to drill a hole in my floor and put sum decent bolts and washers+nuts. But I wasn't sure if this was legal or not, doesn't seem right drilling through the floor. is the WOF man going to pull me up for it?
Wof guys shouldn't pull you up on it. A wof is mainly for safety, and a fire extinguisher mounting really has nothing to do with that.
Cheers,
Brandon
Snaps
Postby B1NZ » Wed May 05, 2010 6:13 pm
just make sure you use 8mm bolts with panel washers on the underside with either nylock nuts or 2 locking nuts.
And be careful not to drill through your fuel and/or brake lines :oops: :oops: :oops:
Subaru GF8 Wagon
B1NZ
Postby Bling » Wed May 05, 2010 8:31 pm
^^ Lol nice one, that's pretty silly really, so would be something i'd do :lol:
As for WOF, I drilled one into the floor of my KP starlet and it went through fine. Just make sure you use the correct (minimum) sizes bolts / washers, otherwise just wasting your time as it won't be allowed on the track. (I assume)
Postby deaf_rattle » Wed May 05, 2010 9:13 pm
B1NZ wrote:just make sure you use 8mm bolts with panel washers on the underside with either nylock nuts or 2 locking nuts.
that reminds me of the time i was tinkering with my mates car stereo to get rid of all the distortion.
I got him to unscrew the amp from the floor in the boot, it started making a loud hissing sound.. he said, what the hell is that? I asked if he had a spare wheel under there.
DOH!
