Using fittings from GSS for brake lines
Postby cat007 » Sun Jun 20, 2010 10:20 am
Hey all
After forking out WAY too much on some brake lines from RaceBrakes (which look very awesome with nice quality fittings) I didn't measure the length properly and they're either too short or too long depending on which way I route them
Now obviously I can't lengthen them but I can shorten them, so can I cut one end off and use some fittings from here:
http://www.gssperformance.co.nz/speedflow-fittings.html
I need a straight on fitting, not a banjo.
What sort should I use?
Hunt
Postby nzae86 » Sun Jun 20, 2010 12:10 pm
Yes unless you want to make it road legal.
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby cat007 » Sun Jun 20, 2010 12:20 pm
nzae86 wrote:Yes unless you want to make it road legal.
It has to be certified anyway. Any idea's if they'll pass these fittings in a cert?
And any idea's what sort I should use?
brake lines
Postby fxgt race » Sun Jun 20, 2010 2:20 pm
I use there brake lines in my race car. I got them to make them and my fault they were to long but i got extra olives and shorten them my self. I need to get of my arse and with ggs as my mates old man owns speedflow in aus and my mate runs the factory.When i had a beer with him last month and asked him how thay made the fittings they are all made on 5 axis cnc machines running 24/7.He has invited me over to look around the factory.
Back to topic yes fittings are all good.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Re: brake lines
Postby cat007 » Sun Jun 20, 2010 4:15 pm
fxgt race wrote:I use there brake lines in my race car. I got them to make them and my fault they were to long but i got extra olives and shorten them my self. I need to get of my ar*e and with ggs as my mates old man owns speedflow in aus and my mate runs the factory.When i had a beer with him last month and asked him how thay made the fittings they are all made on 5 axis cnc machines running 24/7.He has invited me over to look around the factory.
Lucky! Take videos (if the let you) of the machines doing their thing! I'd love to see that lol
Should I use this sort:
http://www.gssperformance.co.nz/compone ... 5&fileout=
Or these ones:
http://www.gssperformance.co.nz/components/com_virtuemart/show_image_in_imgtag.php?filename=resized%2FSpeedflow___Alum_4b94b76f76158_185x165.jpg&newxsize=185&newysize=165&fileout=
Or maybe these?:
http://www.gssperformance.co.nz/components/com_virtuemart/show_image_in_imgtag.php?filename=resized%2FSpeedflow___Stee_4b94b937b388f_185x165.jpg&newxsize=185&newysize=165&fileout=
I've really got no idea which ones are best for my purpose lol
Cheers :)
Hunt
Postby Malcolm » Sun Jun 20, 2010 4:18 pm
I would be nervous about using anything other than crimp fittings for your brake lines. Go see Alert Engineering and get them to put proper fittings on. Don't take shortcuts, you probably want your brakes to work.
Postby deaf_rattle » Sun Jun 20, 2010 5:30 pm
Malcolm wrote:I would be nervous about using anything other than crimp fittings for your brake lines. Go see Alert Engineering and get them to put proper fittings on. Don't take shortcuts, you probably want your brakes to work.
do we want his brakes to work though?
Postby DexGT » Sun Jun 20, 2010 7:39 pm
pretty certain that you can't use screw together fittings on brake lines for road use i.e if you want a WOF
DexGT
Re: brake lines
Postby Bazda » Sun Jun 20, 2010 8:47 pm
Or these ones:
Or maybe these?:
Cheers :)
Hunt
No to the first one, they are for rubber braided hose.
2nd one is for teflon braided hose and is aluminium
3rd one is for teflon braided hose but its steel.
And no you cant do this your self. If they can come apart by screwing they most likely are not road legal.
The road legal ones are all crimped together as Malcolm has stated. They also come with a certificate or a tag on the lines that say so.
Alert Motorsport is the place to go.
Postby cat007 » Sun Jun 20, 2010 9:29 pm
Barry have you got any pics of your brake lines and how you've run them for those calipers?
Postby Bazda » Sun Jun 20, 2010 9:41 pm
They are -3 sized lines. The part going into the caliper is 1/8th NPT to -3. Then a 45deg fitting on the brake line, most people would use 90deg though.
Postby cat007 » Sun Jun 20, 2010 9:58 pm
Bazda wrote:They are -3 sized lines. The part going into the caliper is 1/8th NPT to -3. Then a 45deg fitting on the brake line, most people would use 90deg though.
Hmmmm sweet. I'll have another look tomorrow evening and see what I can do.
Don't suppose you'd care to take a guess at what it'd cost to get them to cut my lines to shorten them and out another fitting on?
I wonder of they could do that for ~$50 a side....
Postby Malcolm » Sun Jun 20, 2010 10:25 pm
should easily be able to do it for that much
Postby Bazda » Mon Jun 21, 2010 1:56 pm
Just re-thinking that idea.
Alert will most likely not certify then as they didn't make them in the first place.
So they can prob put the crimped end on but it still wont be road legal of get you a WOF.
Postby cat007 » Mon Jun 21, 2010 2:09 pm
Bazda wrote:Just re-thinking that idea.
Good point. I'll go back to racebrakes and see what they'll charge for it
Hunt
Postby cat007 » Wed Jun 30, 2010 11:31 pm
Well $70 for them to put a 90degree fitting on each end. Not bad.
Although I think a 45 would've been better....
I like em big ;)
Users browsing this forum: Bing [Bot] and 15 guests
