Supra was just serviced at toyota and ...
Postby escortman » Mon Jul 12, 2010 8:17 am
ok so a couple days before i picked up the supra it had a oil/filter and brake service at toyota.
now the reciept says front pad kit and front disk machine but the car has a brake shudder under heavy breaking
what im wanting to know is can i take it back to them even though im the new owner? if not ill do it myself but if theyr at fault they should have to fix it no matter what?
i think whats happened is that beause the discs look almost new they haven't bothered machineing them completely or something like that
4x4 toyota blizzard offroader
escortman
Postby sergei » Mon Jul 12, 2010 9:06 am
You have the receipt, just come in there and complain, who cares who is the owner. Also before you do anything re-torque your wheel nuts, that might alleviate shuddering. Saying that I believe toyota disks are not machinable, and they are too skinny and warped now.
Postby Mr. Mainstream » Mon Jul 12, 2010 9:16 am
screw it. take it back in with receipt,wave it around point and make noises.
One of my escorts came with a headunit/speakers proff installed with receipt from old owner, i took back to the old place and was sorted.
they wont remember faces 8)
btw is there a rule of thumb to knowing when drums are getting on?
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby FLAWLES » Mon Jul 12, 2010 9:41 am
come back on workman ship
you paid for a service and that service is not up to the task
you have every right to,
most morden service histroy list's licence plates for info so they can type that in and bring up all the info
they cant re charge you either, they will be very very checky if they did
FLAWLES
Postby Adamal » Mon Jul 12, 2010 10:25 am
Which dealership?
Postby Prymal » Mon Jul 12, 2010 12:39 pm
If you get stuck , and need to replace the rotors and pads yourself , pop me a PM , ill see how i can help you out brakes wise
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby RunningRich » Mon Jul 12, 2010 1:54 pm
Disks and pads are not the only causes of brake judder. Could be worn bushings or other issues.
Also depends whether last owner paid them to simply replace pads and disks or to fix a judder issue. Just becuase they replaced pads it does not mean they take all responsibility for the vehicle after that.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby escortman » Mon Jul 12, 2010 6:03 pm
sergei wrote:You have the receipt, just come in there and complain, who cares who is the owner. Also before you do anything re-torque your wheel nuts, that might alleviate shuddering. Saying that I believe toyota disks are not machinable, and they are too skinny and warped now.
yeh il give em a nip up and see if anything changes, o true iv never heard that before?
FLAWLES wrote:come back on workman ship
yeh it has the rego, vin etc on the tax invoice but also has the old owners details on it as well, was just wondering if this would cause issuse?
Adamal wrote:Which dealership?
greylynn
classique71 wrote:If you get stuck , and need to replace the rotors and pads yourself , pop me a PM , ill see how i can help you out brakes wise
sweet if they are poked and they arent going to fix it, ill probably just go to the big turbo brakes but will PM
RunningRich wrote:Disks and pads are not the only causes of brake judder. Could be worn bushings or other issues.
yeh i realise that but the fact it does it only under heavy braking but not low to med?
na it says on reciept replace worn front pads, pad kit, front disk machine and brake fluid
escortman
Postby 1I1 » Mon Jul 12, 2010 6:29 pm
escortman wrote:yeh i realise that but the fact it does it only under heavy braking but not low to med?
Not ABS kicking in?
TRD Clicky >>Here
1I1
Postby escortman » Mon Jul 12, 2010 6:31 pm
thats what a mate suggested but im sure im not stomping on them that hard
escortman
Postby Scottie » Mon Jul 12, 2010 7:01 pm
Might pay to try 'testing' the abs on a gravel/grass/wet road if unsure about what abs feels like. Quite noticeable.
Scottie
Postby tomtom » Mon Jul 12, 2010 8:56 pm
stop been a homo and jack it up an have a look..u could of done it by the time you write a novel on here
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby BZG Wagon » Mon Jul 12, 2010 9:22 pm
How do you know the previous owner didn't warp the brakes? Customary 'last thrash' and all?
Toyota care about their reputation so they'll probably sort it for you, especially if you complain loudly enough.
But IMO the previous owner should have contacted or taken it straight back to Toyota if there was a problem. Or you should have contacted the previous owner to get it sorted when you picked it up.
BZG Wagon
Postby THA SHZ » Tue Jul 13, 2010 10:33 am
a common problem that can happen when putting discs back together is that if they dont clean around the hub it can make the disc sit slightly askew , quite an easy fix , disassemble , clean with a wire brush and re assemble , if you are capable , might be an idea to do it yourself , then you know for sure . :wink:
THA SHZ
Postby escortman » Tue Jul 13, 2010 10:39 pm
yeh going to have a suss this weekend
escortman
Postby christopher j » Thu Jul 15, 2010 11:18 am
has it got aftermarket alloys? and if so, has it got locator rings?
christopher j
Postby Zak » Fri Jul 16, 2010 9:21 pm
I work at the Grey Lynn dealership, flick me a pm with the rego and I will find out what was done and see if I can get it sorted for you.
Zak
Postby escortman » Sun Jul 18, 2010 9:19 pm
na running the stock 16s
escortman
Postby BlakJak » Wed Jul 28, 2010 10:03 am
I used to use Giltrap City in Grey Lynn all the time, never had any dramas, no doubt they'll sort it for you if you talk to them about it and provide receipt etc.
BlakJak
PS yes, old thread. did it get sorted?
BlakJak
Users browsing this forum: Bing [Bot] and 15 guests
