RomanV wrote: Mr Mainstream: The king of the Pushrods?!
sergei wrote:You have the receipt, just come in there and complain, who cares who is the owner. Also before you do anything re-torque your wheel nuts, that might alleviate shuddering. Saying that I believe toyota disks are not machinable, and they are too skinny and warped now.
FLAWLES wrote:come back on workman ship
you paid for a service and that service is not up to the task
you have every right to,
most morden service histroy list's licence plates for info so they can type that in and bring up all the info
they cant re charge you either, they will be very very checky if they did
Adamal wrote:Which dealership?
classique71 wrote:If you get stuck , and need to replace the rotors and pads yourself , pop me a PM , ill see how i can help you out brakes wise
RunningRich wrote:Disks and pads are not the only causes of brake judder. Could be worn bushings or other issues.
Also depends whether last owner paid them to simply replace pads and disks or to fix a judder issue. Just becuase they replaced pads it does not mean they take all responsibility for the vehicle after that.
escortman wrote:yeh i realise that but the fact it does it only under heavy braking but not low to med?
na it says on reciept replace worn front pads, pad kit, front disk machine and brake fluid
