dnalunchie wrote:GTB's are good bang for buck if they are STANDARD.
sergei wrote:Lets start with GTB:
$&#$% turbos
$&#$% shocks = $$$ to replace.
Check for diff bind
Leaky cam covers come as standard
Check if cam belt was done (other wise $$$).
Being slow and having a hole ~5500rpm is a normal thing for those.
Primera NEO:
gutless
watch out for sludge in the motor
watch out for noisy chain (especially startup on cold).
Caldina GTT:
Make sure it does not have any boost taps
Ask what fuel it runs (word it as if you don't know what it needs)
Make sure you check for blow by
Coils could be a problem (run it from cold).
And check infamous warped manifold problem
Check when cambelt was done (could be $$$).
EDIT: primera will be the most boring car out of all those, it is so bland that it will put your granpa asleep.
Mr Revhead wrote:Re the GT-B shocks, most, if not all are Bilsteins. $$$ to replace.
Either a rebuild which is around 3-500 each or something silly like $700 from Subaru.
Mr Revhead wrote:Pretty sure standard shocks are not a straight swap.
snwtoy wrote:I also appreciate the extras like heated side mirrors
Users browsing this forum: Bing [Bot], Google [Bot] and 28 guests
